Want to have -classpath myjar.jar and then update myjar.jar with the newly compiled class [message #275329] |
Sat, 06 November 2004 13:45 |
Hi!
I am sorry if this is to much of a newbie question, but i do not know
where else to turn and i have tried reading the manual for the solution
without success (but it's probably there somewhere). I have just started
to use Eclipse but it looks really good, but i am an not that familiar
with it yet so please bare with me. :-)
WHAT I WANT TO DO
I usually have a .bat file containging three (long) lines with the below
content to compile my code and and update an existing jar file with the
new class:
javac -cp JAIF-ass1.jar -source 1.4 PropertyMapCord.java
PropertyMap.java BehaviorHandler.java WalkAndClean.java
RobotController.java WalkShortestPathTo.java PropertyMapNode.java
jar -uf JAIF-ass1.jar RobotController.class PropertyMapCord.class
PropertyMap.class BehaviorHandler.class WalkAndClean.class
WalkShortestPathTo.class PropertyMapNode.class
del *.class
However i do not know how to do this using Eclipse (latest relaese run
under Windows XP with Sun's JDK). What i want is to compile my classes,
which are dependant on the classes inside JAIF-ass1.jar, and then update
the JAIF-ass1.jar with the resulting classes. As the last thing i do i
remove all *.class files as i have no need for them lying around.
WHAT I HAVE DONE SO FAR
I have installed Eclipse, and got it running fine normally. I then
create a (Java) project and import (from file system) the .java files as
well as the .jar file. It looks good, but i get a lot of errors
immediatly as the necessary classes which my code is dependent on is
inside the .jar file...
With hope of some help, best regards Kent
FUDForum. Page generated in 0.06823 seconds
