Home » Eclipse Projects » Eclipse Platform » XMLSpy 2005 plugin crash
XMLSpy 2005 plugin crash [message #275324] Sat, 06 November 2004 12:08 Go to next message
Originally posted by: lujhuang.consultant.com
I downloaded Altova's XMLSpy 2005 Home Edition and its Eclipse pluggin.
But it kept crashing my eclipse - Eclipse Platform Version: 3.1.0 Build
id: 200410130800. I can't start eclipse at all. Any help would be
appreciated. The error message is:
!ENTRY org.eclipse.ui 4 0 Nov 06, 2004 08:42:35.109
!MESSAGE java.lang.ArrayIndexOutOfBoundsException
!STACK 0
at java.lang.System.arraycopy(Native Method)
org.eclipse.swt.internal.image.WinICOFileFormat.convertPad(W inICOFileFormat.java:28)
org.eclipse.swt.internal.image.WinICOFileFormat.loadIcon(Win ICOFileFormat.java:130)
org.eclipse.swt.internal.image.WinICOFileFormat.loadFromByte Stream(WinICOFileFormat.java:111)
org.eclipse.swt.internal.image.FileFormat.loadFromStream(Fil eFormat.java:47)
at org.eclipse.swt.internal.image.FileFormat.load(FileFormat.ja va:75)
at org.eclipse.swt.graphics.ImageLoader.load(ImageLoader.java:1 25)
at org.eclipse.swt.graphics.ImageData.<init>(ImageData.java:308)
org.eclipse.jface.resource.URLImageDescriptor.getImageData(U RLImageDescriptor.java:57)
org.eclipse.jface.resource.ImageDescriptor.createImage(Image Descriptor.java:169)
org.eclipse.jface.resource.ImageDescriptor.createImage(Image Descriptor.java:123)
org.eclipse.jface.resource.ImageDescriptor.createImage(Image Descriptor.java:101)
org.eclipse.jface.action.ActionContributionItem$ImageCache.g etImage(ActionContributionItem.java:435)
org.eclipse.jface.action.ActionContributionItem$ImageCache.a ccess$1(ActionContributionItem.java:420)
org.eclipse.jface.action.ActionContributionItem.updateImages (ActionContributionItem.java:1284)
org.eclipse.jface.action.ActionContributionItem.update(Actio nContributionItem.java:1113)
org.eclipse.jface.action.ActionContributionItem.fill(ActionC ontributionItem.java:714)
at org.eclipse.jface.action.ToolBarManager.update(ToolBarManage r.java:309)
org.eclipse.jface.action.ToolBarManager.createControl(ToolBa rManager.java:101)
org.eclipse.jface.action.ToolBarContributionItem.fill(ToolBa rContributionItem.java:190)
at org.eclipse.jface.action.CoolBarManager.update(CoolBarManage r.java:907)
org.eclipse.ui.internal.WorkbenchWindow.updateActionBars(Wor kbenchWindow.java:2267)
org.eclipse.ui.internal.WorkbenchWindow.updateActionSets(Wor kbenchWindow.java:2336)
org.eclipse.ui.internal.WorkbenchWindow$4.run(WorkbenchWindo w.java:2151)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
org.eclipse.ui.internal.WorkbenchWindow.setActivePage(Workbe nchWindow.java:2125)
org.eclipse.ui.internal.WorkbenchWindow.busyOpenPage(Workben chWindow.java:574)
org.eclipse.ui.internal.WorkbenchWindow$3.run(WorkbenchWindo w.java:1262)
org.eclipse.ui.internal.WorkbenchWindow.openPage(WorkbenchWi ndow.java:1259)
org.eclipse.ui.internal.Workbench.openFirstTimeWindow(Workbe nch.java:1046)
org.eclipse.ui.internal.WorkbenchConfigurer.openFirstTimeWin dow(WorkbenchConfigurer.java:178)
org.eclipse.ui.application.WorkbenchAdvisor.openWindows(Work benchAdvisor.java:661)
at org.eclipse.ui.internal.Workbench.init(Workbench.java:860)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1391)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:271)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:144)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:102)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:335)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:273)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:129)
at org.eclipse.core.launcher.Main.basicRun(Main.java:185)
at org.eclipse.core.launcher.Main.run(Main.java:704)
at org.eclipse.core.launcher.Main.main(Main.java:688)
Re: XMLSpy 2005 plugin crash [message #275349 is a reply to message #275324] Sun, 07 November 2004 01:08 Go to previous messageGo to next message
Originally posted by: me.BarryBurd.com
I'm having the same problem. That points to the XMLSpy plugin as the
culprit. My problem is, even if I reinstall Eclipse, I can't run it. The
plugin must have corrupted something outside of the Eclipse installation
directory. Yuch!
Re: XMLSpy 2005 plugin crash [message #282153 is a reply to message #275349] Sun, 06 March 2005 11:06 Go to previous messageGo to next message
Originally posted by: neyman.email.uophx.edu
I strongly suspect that the problem is the plugin is 3.0 specific. It says
so.
Based on your experiences, I'll wait until a 3.1 plugin is released. I
assume it's under development.
That's a pain, because I've been enjoying 3.1m5... and I want to use XMLSpy
for the next phase of a project I'm working on.
Hi ho. Welcome to the bleeding edge.
ROGER NEYMAN
roger.neyman@pobox.com
"Barry Burd" <me@BarryBurd.com> wrote in message
news:cmke4r$ivn$1@eclipse.org...
> directory. Yuch!
Re: XMLSpy 2005 plugin crash [message #282308 is a reply to message #282153] Tue, 08 March 2005 14:20 Go to previous message
One of my co-workers has successfully installed it and is using it. Go
figure.
ROGER NEYMAN
neyman@email.uophx.edu
Pacific Time Zone - 503-504-3558
"ROGER NEYMAN" <neyman@email.uophx.edu> wrote in message
news:d0f9ps$btq$1@www.eclipse.org...
> so.
XMLSpy
> ROGER NEYMAN
> > directory. Yuch!
Previous Topic:Junit Plugin Test: Waiting for Builder
Next Topic:NoSuchMethodException
Current Time: Sat Nov 22 01:30:15 EST 2025
Powered by FUDForum. Page generated in 0.09750 seconds
