Home » Eclipse Projects » Eclipse Platform » Sorting on a checkbox column in a Table
Sorting on a checkbox column in a Table [message #275008] Tue, 02 November 2004 11:30 Go to next message
Hi-
I have a table constructed with the SWT.CHECK option. I'm wondering if
it is possible to sort the checkbox column. I've implemented a sorter
that does the right thing (the rows get sorted correctly when the
checkbox column is clicked), but the checkboxes do not move along with
their rows. Is there any way to have the checkboxes move?
- Mia
Re: Sorting on a checkbox column in a Table [message #275025 is a reply to message #275008] Tue, 02 November 2004 17:25 Go to previous message
Mia,
How do you change the order of the TableItems? I assume that you dispose
and recreate them (at least the ones that need to move) each time? If so,
then those TableItems that do not change between reorderings should bring
their checked state with them even if their index changes, and if this isn't
happening then you should log a bug report with Platform - SWT. TableItems
that are disposed and then recreated do need to have their initial checked
state set, of course.
Grant
"Mia Stern" <mia_stern@us.ibm.com> wrote in message
news:cm8cme$ldu$1@eclipse.org...
> Hi-
> - Mia
Previous Topic:Default TreeViewer Tooltip
Next Topic:Eclipse slow over ClearCase network drive
Current Time: Sun Oct 26 06:58:21 EDT 2025
Powered by FUDForum. Page generated in 0.04329 seconds
