Adding to the plugin classpath [message #274964] |
Mon, 01 November 2004 20:29  |
Originally posted by: dcorbin.enttek.com
I'm attempting to profile a plugin. The tool I'm using instruments .class
files. Then, an additional jar file is necesary while the application is
running with the instrumented classes. I've tried to add this .jar to the
plugin.xml run-time librares on the runtime tab, however, when I run the
Ecilpse workbench, this JAR file is not found.
Anybody got any ideas on what I'm not doing correctly?
David
Re: Adding to the plugin classpath [message #275550 is a reply to message #274964] |
Tue, 09 November 2004 08:39  |
You probably didn't put that JAR inside your plug-in.
Dani
>David
FUDForum. Page generated in 0.04389 seconds
