Home » Eclipse Projects » Eclipse Platform » : java.io.IOException: An error occurred while locking file
: java.io.IOException: An error occurred while locking file [message #274637] Wed, 27 October 2004 04:48 Go to next message
I am running eclipse in HP-UX envrionment. I get the following error while
i call ./eclipse -vmargs -XdoCloseWithReadPending :
"Caused by: java.io.IOException: An error occurred while locking file
"/home/roopam/eclipse/eclipse/configuration/org.eclipse.core
runtime/.manager/.fileTableLock": "Invalid argument". A probably reason
is that the file system or Runtime Environment does not
support file locking. You may want to choose a different location, or
disable file locking (using the osgi.locking property), but
this can cause data corruption."
Snippet of the log file is as below:
!SESSION Oct 27, 2004 14:17:36.442
eclipse.buildId=M200409161125
java.version=1.4.1.00
java.vendor=Hewlett-Packard Co.
BootLoader constants: OS=hpux, ARCH=PA_RISC, WS=motif, NL=en
!ENTRY
initial@reference :file:/home/roopam/eclipse/eclipse/plugins/org.eclipse.core. runtime_3.0.1/
0 0 Oct 27, 2004 14:17:36.491
!MESSAGE FrameworkEvent.ERROR
!STACK 0
org.osgi.framework.BundleException: Exception in
org.eclipse.core.internal.runtime.PlatformActivator.start() of bundle
org.eclips
e.core.runtime.
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:975)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:937)
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:421)
org.eclipse.osgi.framework.internal.core.AbstractBundle.resu me(AbstractBundle.java:366)
org.eclipse.osgi.framework.internal.core.Framework.resumeBun dle(Framework.java:999)
org.eclipse.osgi.framework.internal.core.StartLevelManager.r esumeBundles(StartLevelManager.java:577)
org.eclipse.osgi.framework.internal.core.StartLevelManager.i ncFWSL(StartLevelManager.java:488)
org.eclipse.osgi.framework.internal.core.StartLevelManager.d oSetStartLevel(StartLevelManager.java:273)
org.eclipse.osgi.framework.internal.core.StartLevelManager.d ispatchEvent(StartLevelManager.java:444)
org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEve nt(EventManager.java:186)
org.eclipse.osgi.framework.eventmgr.EventThread.run(EventThr ead.java:104)
org.eclipse.core.runtime.adaptor.Locker_JavaNio.lock(Locker_ JavaNio.java:42)
org.eclipse.osgi.service.datalocation.FileManager.lock(FileM anager.java:219)
org.eclipse.osgi.service.datalocation.FileManager.open(FileM anager.java:423)
org.eclipse.core.internal.runtime.InternalPlatform.initializ eRuntimeFileManager(InternalPlatform.java:391)
org.eclipse.core.internal.runtime.InternalPlatform.start(Int ernalPlatform.java:38
Can anyone tell how to overcome with the error?
Rgds,
Roopa
Re: : java.io.IOException: An error occurred while locking file [message #274673 is a reply to message #274637] Wed, 27 October 2004 10:20 Go to previous messageGo to next message
Originally posted by: chaves.nospam.inf.ufsc.br.please
See:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=44735#c37
Roopa wrote:
> !ENTRY
> !STACK 0
> org.eclips
> e.core.runtime.
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Rgds,
> Roopa
Re: : java.io.IOException: An error occurred while locking file [message #274978 is a reply to message #274673] Tue, 02 November 2004 04:31 Go to previous message
The error persists inspite of running with the following option
/eclipse –vmargs -Dorg.eclipse.core.runtime.ignoreLockFile
Any other way to overcome this and get started on the HP-UX ?
Rgds,
Roopa
Rafael Chaves wrote:
> See:
> Roopa wrote:
> > Hi,
> > !ENTRY
> > !STACK 0
> > org.eclips
> > e.core.runtime.
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > Thanks,
> > Rgds,
> > Roopa
Previous Topic:IncrementalProjectBuilder and IWorkspaceRunnable
Next Topic:Dynamic Menubar
Current Time: Tue Nov 11 07:21:43 EST 2025
Powered by FUDForum. Page generated in 0.12327 seconds
