Home » Eclipse Projects » Eclipse Platform » Config file
Config file [message #274156] Mon, 18 October 2004 04:04 Go to next message
Hi everybody,
I was playing with different eclipse versions lately (mostly
3.0.1->3.1_preX). After removing one and installing a new one, the new one
came up with settings which were set by the former one.
I removed /lib/eclipse*, and the worspace directory.
Now I was wondering, where eclipse saves its config files.
I'm running gentoo here and one thing I also noticed was that on my x86_32
with blackdown-1.4.2 eclipse randomly hangs with the java vm using up to
100% CPU time. I have no chance but killing it. (Same happens with sun's VM
- various versions). This usually happens on dialogs, like the file open
dialog or slider movements.
Is there a way I get debugging output?
On my x86_64 running also blackdown-1.4.2 (server of course ;) ) the same
eclipse ebuild runs just fine.
Thanks a lot in advance,
Fabian
Re: Config file [message #274171 is a reply to message #274156] Mon, 18 October 2004 07:19 Go to previous message
Originally posted by: pascal.ibm.canada
The config file is located in the $HOME/.eclipse/ folder.
To get output and track this kind of problem you can run with
-consoleLog (which will force eclipse to run with java.exe instead of
javaw.exe). When you hang you can try to do a kill -3 <eclipsePid>,
which will generate a stack trace.
PaScaL
Fabian Wolf wrote:
> Hi everybody,
> Fabian
Previous Topic:jface source code
Next Topic:Error : Reference to undefined variable workspace_loc
Current Time: Sun Oct 19 08:30:43 EDT 2025
Powered by FUDForum. Page generated in 0.03205 seconds
