Home » Eclipse Projects » Eclipse Platform » Plugins sometimes not loading in 3.0.1?
Plugins sometimes not loading in 3.0.1? [message #273170] Thu, 30 September 2004 23:07 Go to next message
Originally posted by: anagnost.comcast.net
I'm having a hard time diagnosing this problem, here's the sequence:
1. Downloaded eclipse-SDK-3.0.1-win32.zip
2. Unzip'd to c:\
3. Downloaded several plugins.
net.sf.solareclipse_0.4.1.bin.dist.zip
ru.nlmk.eclipse.plugins.profiler_0.5.31.zip
jadclipse_b206.zip
4. Startup eclipse, I accept the standard workspace directory,
everything's fine, shut down
5. Install one or more of the above plugins, startup eclipse again,
everything's fine (the plugins I installed are recognized and loaded)
6. Copy a project folder to: c:\eclipse\workspace, I import it, the
project works, I shut down eclipse
7. Install a new plugin to the plugins directory, startup eclipse, plugin
is not recognized, I can't figure out how to get it to load
It seems as if once I start using my project, I can no longer add new
plugins
Re: Plugins sometimes not loading in 3.0.1? [message #273171 is a reply to message #273170] Fri, 01 October 2004 00:21 Go to previous message
To ensure a consistent story when altering the set of plugins used for
Eclipse ensure to make use of the -clean option.
Darins
"Ted" <anagnost@comcast.net> wrote in message
news:cjihmd$ipq$1@eclipse.org...
> 2. Unzip'd to c:\
> jadclipse_b206.zip
> plugins
Previous Topic:Creating a Project like the PDE
Next Topic:commit sets - intended behaviour ?
Current Time: Sun Jul 13 18:56:59 EDT 2025
Powered by FUDForum. Page generated in 0.25308 seconds
