Home » Eclipse Projects » Eclipse Platform » java.beans.XMLDecoder parse error in Plugin
java.beans.XMLDecoder parse error in Plugin [message #272988] Wed, 29 September 2004 14:04 Go to next message
I've got a strange situation whereby I am unable to parse a file generated
by java.beans.XMLEncoder using the XMLDecoder within a plugin environment.
It feels like some kind of class loading problem whereby the XMLDecoder
cannot locate the com.eyeris.common.fileserver.FileServerFile class but I
can't figure it out as the plugin declares the correct dependencies and I'm
able to instantiate a dummy class instance.
Here's the test that works as a stand-alone java project, invoking the same
code within the context of a plugin fails everytime. The file I'm reading
and the stack trace from the plugin invocation are included below:
public class decodertest {
public static void main(String args[]) {
ExceptionListener listener = new ExceptionListener() {
public void exceptionThrown(Exception e) {
e.printStackTrace();
// Create dummy instance to verify class loading
com.eyeris.common.fileserver.FileServerFile fsf = new
com.eyeris.common.fileserver.FileServerFile();
XMLDecoder d = null;
try {
d = new XMLDecoder(
new BufferedInputStream(
new FileInputStream("C:/temp/XMLDecoderIn.txt")), null,
listener);
} catch (FileNotFoundException e) {
// TODO Auto-generated catch block
Object result = d.readObject();
d.close();
The file I'm trying to read/parse:
<java version="1.4.2_05" class="java.beans.XMLDecoder">
<object class="java.util.LinkedList">
<void method="add">
<object class="com.eyeris.common.fileserver.FileServerFile">
<void property="length">
<long>0</long>
</void>
<void property="name">
<string>condcomponent.cond</string>
</void>
<void property="url">
<string>epfs://localhost/condcomponent.cond</string>
</void>
</object>
</void>
</object>
</java>
Stack trace:
at org.eclipse.core.launcher.Main.main(Main.java:628)
at java.beans.Statement.invoke(Statement.java:454)
at java.beans.Expression.getValue(Expression.java:101)
at java.beans.ObjectHandler.getValue(XMLDecoder.java:241)
at java.beans.ObjectHandler.eval(XMLDecoder.java:262)
at java.beans.ObjectHandler.startElement(XMLDecoder.java:344)
org.xml.sax.helpers.XMLReaderAdapter.startElement(XMLReaderA dapter.java:333)
at org.apache.crimson.parser.Parser2.maybeElement(Parser2.java: 1674)
at org.apache.crimson.parser.Parser2.content(Parser2.java:1963)
at org.apache.crimson.parser.Parser2.maybeElement(Parser2.java: 1691)
at org.apache.crimson.parser.Parser2.parseInternal(Parser2.java :667)
at org.apache.crimson.parser.Parser2.parse(Parser2.java:337)
at org.apache.crimson.parser.XMLReaderImpl.parse(XMLReaderImpl. java:448)
at org.xml.sax.helpers.XMLReaderAdapter.parse(XMLReaderAdapter. java:223)
at javax.xml.parsers.SAXParser.parse(SAXParser.java:314)
at javax.xml.parsers.SAXParser.parse(SAXParser.java:89)
at java.beans.XMLDecoder.<init>(XMLDecoder.java:88)
com.eyeris.eyeprofit.ui.repository.core.EPRepositoryCorePlug in.readFile(EPRe
positoryCorePlugin.java:103)
com.eyeris.eyeprofit.ui.repository.core.EPRepositoryCorePlug in.start(EPRepos
itoryCorePlugin.java:89)
org.eclipse.osgi.framework.internal.core.BundleContextImpl$1 .run(BundleConte
xtImpl.java:958)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(Bu
ndleContextImpl.java:954)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleConte
xtImpl.java:937)
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.j
ava:421)
org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle
..java:293)
org.eclipse.core.runtime.adaptor.EclipseClassLoader.findLoca lClass(EclipseCl
assLoader.java:110)
org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleL
oader.java:371)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader
..java:402)
org.eclipse.osgi.framework.adaptor.core.AbstractClassLoader. loadClass(Abstra
ctClassLoader.java:93)
at java.lang.ClassLoader.loadClass(ClassLoader.java:235)
org.eclipse.osgi.framework.internal.core.BundleLoader.loadCl ass(BundleLoader
..java:307)
org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.jav
a:336)
org.eclipse.osgi.framework.internal.core.AbstractBundle.load Class(AbstractBu
ndle.java:1313)
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExte
nsion(ConfigurationElement.java:131)
nsion(ConfigurationElement.java:124)
nsion(ConfigurationElement.java:113)
at org.eclipse.ui.internal.WorkbenchPlugin$1.run(WorkbenchPlugi n.java:196)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
org.eclipse.ui.internal.WorkbenchPlugin.createExtension(Work benchPlugin.java
:193)
org.eclipse.ui.internal.registry.ViewDescriptor.createView(V iewDescriptor.ja
va:76)
at org.eclipse.ui.internal.ViewFactory$1.run(ViewFactory.java:2 87)
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java
:615)
at org.eclipse.core.runtime.Platform.run(Platform.java:747)
at org.eclipse.ui.internal.ViewFactory.busyRestoreView(ViewFact ory.java:259)
at org.eclipse.ui.internal.ViewFactory$2.run(ViewFactory.java:5 16)
at org.eclipse.ui.internal.ViewFactory.restoreView(ViewFactory. java:514)
org.eclipse.ui.internal.ViewFactory$ViewReference.getPart(Vi ewFactory.java:1
02)
org.eclipse.ui.internal.ViewFactory$ViewReference.getView(Vi ewFactory.java:1
66)
org.eclipse.ui.internal.WorkbenchPage.restoreState(Workbench Page.java:2507)
org.eclipse.ui.internal.WorkbenchWindow.restoreState(Workben chWindow.java:13
72)
at org.eclipse.ui.internal.Workbench.restoreState(Workbench.jav a:1224)
at org.eclipse.ui.internal.Workbench.access$10(Workbench.java:1 185)
at org.eclipse.ui.internal.Workbench$13.run(Workbench.java:1096 )
:615)
at org.eclipse.ui.internal.Workbench.restoreState(Workbench.jav a:1029)
org.eclipse.ui.internal.WorkbenchConfigurer.restoreState(Wor kbenchConfigurer
..java:167)
org.eclipse.ui.application.WorkbenchAdvisor.openWindows(Work benchAdvisor.jav
a:652)
at org.eclipse.ui.internal.Workbench.init(Workbench.java:819)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1325)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:254)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:141)
com.eyeris.eyeprofit.modelconfig.ui.ModelConfigApplication.r un(ModelConfigAp
plication.java:35)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.
java:335)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:273)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:129)
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl
..java:25)
at org.eclipse.core.launcher.Main.basicRun(Main.java:183)
at org.eclipse.core.launcher.Main.run(Main.java:644)
Re: java.beans.XMLDecoder parse error in Plugin [message #272994 is a reply to message #272988] Wed, 29 September 2004 14:36 Go to previous message
Looks like I found the bug associated with this issue so disregard this
message. For reference, it is:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=30588
"Paul Wuethrich" <paul.wuethrich@eye-ris.com> wrote in message
news:cjet5p$2qe$1@eclipse.org...
I'm
same
> try {
> d = new XMLDecoder(
> listener);
> d.close();
> <void method="add">
> <long>0</long>
> </void>
> </void>
> </void>
> </object>
> </void>
> </object>
> </java>
> Stack trace:
> java.lang.NullPointerException
> at
> at
> at
> at
> xtImpl.java:958)
> at java.security.AccessController.doPrivileged(Native Method)
> at
> at
> xtImpl.java:937)
> at
> ava:421)
> at
> .java:293)
> at
> assLoader.java:110)
> at
> oader.java:371)
> at
> .java:402)
> at
> at
> .java:307)
> at
> a:336)
> at
> ndle.java:1313)
> at
> at
> at
> at
> :193)
> at
> va:76)
> at
> :615)
> at
> at
> 02)
> at
> 66)
> at
> at
> 72)
> at
> :615)
> at
> .java:167)
> at
> a:652)
> at
> at
> plication.java:35)
> at
> java:335)
> at
> at
> at
> at
> .java:25)
Previous Topic:extracting java metadata
Next Topic:the addressbook swt sample
Current Time: Fri Nov 07 05:43:07 EST 2025
Powered by FUDForum. Page generated in 0.04879 seconds
