Home » Eclipse Projects » Eclipse Platform » Listen for click on editor tab
Listen for click on editor tab [message #272968] Wed, 29 September 2004 11:13 Go to next message
Originally posted by: paul.wells.modelistic.com
I have an editor which needs to do various things when it gains the focus
(refresh enablement of actions etc). The editor extends EditorPart and
contains a single Canvas.
The problem is that switching between editor instances by clicking on the
tabs at the top of the editor pane doesn't give focus to the Canvas - you
have to click down on the canvas each time to cause a change of focus.
How can I listen for changes in selection of editor (either by clicks on
the tabs or any other means), so that I can automatically pass the focus
to the canvas?
Thanks very much
Re: Listen for click on editor tab [message #273038 is a reply to message #272968] Thu, 30 September 2004 08:42 Go to previous message
The proper way to do this is to override "setFocus()".
> to the canvas?
While this is not what you want to be doing, you can listen for the part
activation event -- available from WorkbenchPage.
cheers,
d.
Re: Listen for click on editor tab [message #273176 is a reply to message #272968] Thu, 30 September 2004 08:01 Go to previous message
Originally posted by: scheglov_ke.nlmk.ru
Paul Wells <paul.wells@modelistic.com> wrote:
May be setFocus() for your WorkbenchPart?
> to the canvas?
> Thanks very much
SY, Konstantin.
Advanced Eclipse SWT Designer (http://www.swt-designer.com)
Previous Topic:awt problem in eclipse
Next Topic:Python Plugin
Current Time: Wed Nov 05 12:51:53 EST 2025
Powered by FUDForum. Page generated in 0.04777 seconds
