Home » Eclipse Projects » Buckminster dev » Automated build broken
Automated build broken [message #27017] |
Fri, 31 October 2008 18:42  |
Hi Adrian,
I wanted to have an up date (HEAD) package of Buckminster in my
continuous integration machine (Hudson) so I decided to try your build
script :)
I just checked it out from SVN and launch the default task from within
Eclipse, it worked like a charm until the buckminster.build target.
You'll find the trace below. I don't know if it helps.
Guillaume
> buckminster.build:
> [echo] Building Buckminster
> [java] org.eclipse.buckminster.core.build
> [java] [start AntBuilder(FULL)] : Classpath Emitter - org.eclipse.buckminster.ant
> [java] [end AntBuilder(FULL)]
> [java] [start AntBuilder(FULL)] : Internal Ant Builder support compile (Ant Builder) - org.eclipse.buckminster.ant
> [java] [start AntBuilder(FULL)] : Classpath Emitter - org.eclipse.buckminster.jdt
> [java] [start AntBuilder(FULL)] : Internal Ant Builder support compile (Ant Builder) - org.eclipse.buckminster.jdt
> [java] ERROR: Plug-in org.eclipse.jdt.ui was unable to load class org.eclipse.jdt.internal.ui.propertiesfileeditor.PropertiesF ileDocumentSetupParticipant.
> [java] org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter $TerminatingClassNotFoundException: An error occurred while automatically activating bundle org.eclipse.jdt.ui (346).
> [java] at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .postFindLocalClass(EclipseLazyStarter.java:125)
> [java] at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:427)
> [java] at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin dLocalClass(DefaultClassLoader.java:193)
> [java] at org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:368)
> [java] at org.eclipse.osgi.framework.internal.core.BundleLoader.findCl assInternal(BundleLoader.java:444)
> [java] at org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:397)
> [java] at org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:385)
> [java] at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:87)
> [java] at java.lang.ClassLoader.loadClass(ClassLoader.java:251)
> [java] at org.eclipse.osgi.framework.internal.core.BundleLoader.loadCl ass(BundleLoader.java:313)
> [java] at org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:227)
> [java] at org.eclipse.osgi.framework.internal.core.AbstractBundle.load Class(AbstractBundle.java:1274)
> [java] at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:160)
> [java] at org.eclipse.core.internal.registry.ExtensionRegistry.createE xecutableExtension(ExtensionRegistry.java:867)
> [java] at org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:243)
> [java] at org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutableExtension(ConfigurationElementHandle.java: 51)
> [java] at org.eclipse.core.internal.filebuffers.ExtensionsRegistry.get Extension(ExtensionsRegistry.java:238)
> [java] at org.eclipse.core.internal.filebuffers.ExtensionsRegistry.doG etDocumentSetupParticipants(ExtensionsRegistry.java:361)
> [java] at org.eclipse.core.internal.filebuffers.ExtensionsRegistry.get DocumentSetupParticipants(ExtensionsRegistry.java:383)
> [java] at org.eclipse.core.internal.filebuffers.ResourceExtensionRegis try.getDocumentSetupParticipants(ResourceExtensionRegistry.j ava:119)
> [java] at org.eclipse.core.internal.filebuffers.ResourceTextFileBuffer Manager.createEmptyDocument(ResourceTextFileBufferManager.ja va:161)
> [java] at org.eclipse.core.internal.filebuffers.ResourceTextFileBuffer .initializeFileBufferContent(ResourceTextFileBuffer.java:289 )
> [java] at org.eclipse.core.internal.filebuffers.ResourceFileBuffer.cre ate(ResourceFileBuffer.java:241)
> [java] at org.eclipse.core.internal.filebuffers.TextFileBufferManager. connect(TextFileBufferManager.java:112)
> [java] at org.eclipse.pde.internal.core.builders.ErrorReporter.createD ocument(ErrorReporter.java:71)
> [java] at org.eclipse.pde.internal.core.builders.BuildErrorReporter.pr epareTextBuildModel(BuildErrorReporter.java:512)
> [java] at org.eclipse.pde.internal.core.builders.BuildErrorReporter.va lidate(BuildErrorReporter.java:112)
> [java] at org.eclipse.pde.internal.core.builders.ErrorReporter.validat eContent(ErrorReporter.java:127)
> [java] at org.eclipse.pde.internal.core.builders.ManifestConsistencyCh ecker.validateBuildProperties(ManifestConsistencyChecker.jav a:341)
> [java] at org.eclipse.pde.internal.core.builders.ManifestConsistencyCh ecker.validateProject(ManifestConsistencyChecker.java:256)
> [java] at org.eclipse.pde.internal.core.builders.ManifestConsistencyCh ecker.build(ManifestConsistencyChecker.java:182)
> [java] at org.eclipse.core.internal.events.BuildManager$2.run(BuildMan ager.java:633)
> [java] at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
> [java] at org.eclipse.core.internal.events.BuildManager.basicBuild(Bui ldManager.java:170)
> [java] at org.eclipse.core.internal.events.BuildManager.basicBuild(Bui ldManager.java:201)
> [java] at org.eclipse.core.internal.events.BuildManager$1.run(BuildMan ager.java:253)
> [java] at org.eclipse.core.internal.events.BuildManager.basicBuild(Bui ldManager.java:256)
> [java] at org.eclipse.core.internal.events.BuildManager.basicBuildLoop (BuildManager.java:309)
> [java] at org.eclipse.core.internal.events.BuildManager.build(BuildMan ager.java:341)
> [java] at org.eclipse.core.internal.resources.Workspace.build(Workspac e.java:330)
> [java] at org.eclipse.buckminster.core.commands.Build.internalRun(Buil d.java:61)
> [java] at org.eclipse.buckminster.core.commands.WorkspaceCommand.run(W orkspaceCommand.java:60)
> [java] at org.eclipse.buckminster.cmdline.AbstractCommand.basicRun(Abs tractCommand.java:80)
> [java] at org.eclipse.buckminster.cmdline.Headless.run(Headless.java:1 88)
> [java] at org.eclipse.buckminster.cmdline.Headless.run(Headless.java:1 22)
> [java] at org.eclipse.buckminster.cmdline.Headless.start(Headless.java :113)
> [java] at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:193)
> [java] at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
> [java] at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
> [java] at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:382)
> [java] at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
> [java] at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
> [java] at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
> [java] at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
> [java] at java.lang.reflect.Method.invoke(Method.java:585)
> [java] at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 549)
> [java] at org.eclipse.equinox.launcher.Main.basicRun(Main.java:504)
> [java] at org.eclipse.equinox.launcher.Main.run(Main.java:1236)
> [java] at org.eclipse.equinox.launcher.Main.main(Main.java:1212)
> [java] Caused by: org.osgi.framework.BundleException: Exception in org.eclipse.jdt.internal.ui.JavaPlugin.start() of bundle org.eclipse.jdt.ui.
> [java] at org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:1028)
> [java] at org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:984)
> [java] at org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:346)
> [java] at org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:265)
> [java] at org.eclipse.osgi.framework.util.SecureAction.start(SecureAct ion.java:400)
> [java] at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .postFindLocalClass(EclipseLazyStarter.java:111)
> [java] ... 59 more
> [java] Caused by: org.eclipse.core.runtime.AssertionFailedException: null argument:
> [java] at org.eclipse.core.runtime.Assert.isNotNull(Assert.java:86)
> [java] at org.eclipse.core.runtime.Assert.isNotNull(Assert.java:74)
> [java] at org.eclipse.jface.resource.StringConverter.asString(StringCo nverter.java:800)
> [java] at org.eclipse.jface.preference.PreferenceConverter.setDefault( PreferenceConverter.java:419)
> [java] at org.eclipse.jdt.ui.PreferenceConstants.setRGBValue(Preferenc eConstants.java:3998)
> [java] at org.eclipse.jdt.ui.PreferenceConstants.initializeDefaultValu es(PreferenceConstants.java:3710)
> [java] at org.eclipse.jdt.internal.ui.JavaUIPreferenceInitializer.init ializeDefaultPreferences(JavaUIPreferenceInitializer.java:37 )
> [java] at org.eclipse.core.internal.preferences.PreferenceServiceRegis tryHelper.runInitializer(PreferenceServiceRegistryHelper.jav a:276)
> [java] at org.eclipse.core.internal.preferences.PreferenceServiceRegis tryHelper.applyRuntimeDefaults(PreferenceServiceRegistryHelp er.java:130)
> [java] at org.eclipse.core.internal.preferences.PreferencesService.app lyRuntimeDefaults(PreferencesService.java:367)
> [java] at org.eclipse.core.internal.preferences.DefaultPreferences.app lyRuntimeDefaults(DefaultPreferences.java:163)
> [java] at org.eclipse.core.internal.preferences.DefaultPreferences.loa dDefaults(DefaultPreferences.java:236)
> [java] at org.eclipse.core.internal.preferences.DefaultPreferences.loa d(DefaultPreferences.java:232)
> [java] at org.eclipse.core.internal.preferences.EclipsePreferences.cre ate(EclipsePreferences.java:307)
> [java] at org.eclipse.core.internal.preferences.EclipsePreferences.int ernalNode(EclipsePreferences.java:543)
> [java] at org.eclipse.core.internal.preferences.EclipsePreferences.nod e(EclipsePreferences.java:662)
> [java] at org.eclipse.core.internal.preferences.AbstractScope.getNode( AbstractScope.java:38)
> [java] at org.eclipse.core.runtime.preferences.DefaultScope.getNode(De faultScope.java:68)
> [java] at org.eclipse.ui.preferences.ScopedPreferenceStore.getDefaultP references(ScopedPreferenceStore.java:250)
> [java] at org.eclipse.ui.preferences.ScopedPreferenceStore.getPreferen ceNodes(ScopedPreferenceStore.java:285)
> [java] at org.eclipse.ui.preferences.ScopedPreferenceStore.internalGet (ScopedPreferenceStore.java:475)
> [java] at org.eclipse.ui.preferences.ScopedPreferenceStore.getBoolean( ScopedPreferenceStore.java:387)
> [java] at org.eclipse.jdt.internal.ui.preferences.MembersOrderPreferen ceCache.install(MembersOrderPreferenceCache.java:61)
> [java] at org.eclipse.jdt.internal.ui.JavaPlugin.ensurePreferenceStore BackwardsCompatibility(JavaPlugin.java:414)
> [java] at org.eclipse.jdt.internal.ui.JavaPlugin.start(JavaPlugin.java :361)
> [java] at org.eclipse.osgi.framework.internal.core.BundleContextImpl$2 .run(BundleContextImpl.java:1009)
> [java] at java.security.AccessController.doPrivileged(Native Method)
> [java] at org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:1003)
> [java] ... 64 more
> [java] [start AntBuilder(FULL)] : Classpath Emitter - org.eclipse.buckminster.pde
> [java] [start AntBuilder(FULL)] : Ant tasks compile (Ant Builder) - org.eclipse.buckminster.pde
> [java] Warning: file /home/clitte/test_workspace/build/build/workspace/plugins/ja vax.mail: build.properties does not exist
> [java] Warning: file /home/clitte/test_workspace/build/build/workspace/plugins/or g.apache.commons.codec: build.properties does not exist
> [java] Warning: file /home/clitte/test_workspace/build/build/workspace/plugins/or g.apache.commons.codec/META-INF/MANIFEST.MF, line 1: No required execution environment has been set
> [java] Warning: file /home/clitte/test_workspace/build/build/workspace/plugins/or g.apache.commons.httpclient: build.properties does not exist
> [java] Warning: file /home/clitte/test_workspace/build/build/workspace/plugins/or g.eclipse.buckminster.generic.ui/plugin.xml, line 1: A plug-in manifest must contain at least one extension or extension point
> [java] Warning: file /home/clitte/test_workspace/build/build/workspace/plugins/or g.eclipse.buckminster.opml/src/org/eclipse/buckminster/opml/ parser/OutlineHandler.java, line 23: Unnecessary @SuppressWarnings("hiding")
> [java] Warning: file /home/clitte/test_workspace/build/build/workspace/plugins/or g.eclipse.buckminster.opml/src/org/eclipse/buckminster/opml/ model/Outline.java, line 27: Unnecessary @SuppressWarnings("hiding")
> [java] Warning: file /home/clitte/test_workspace/build/build/workspace/plugins/or g.eclipse.buckminster.core/src/java/org/eclipse/buckminster/ core/rmap/model/URIMatcher.java, line 59: Unnecessary @SuppressWarnings("hiding")
> [java] Warning: file /home/clitte/test_workspace/build/build/workspace/plugins/or g.eclipse.buckminster.core/src/java/org/eclipse/buckminster/ core/reader/IReaderType.java, line 36: The import org.eclipse.ecf.core.security.IConnectContext is never used
> [java] Warning: file /home/clitte/test_workspace/build/build/workspace/plugins/or g.eclipse.buckminster.core/src/java/org/eclipse/buckminster/ core/metadata/model/WorkspaceBinding.java, line 29: Unnecessary @SuppressWarnings("hiding")
> [java] Warning: file /home/clitte/test_workspace/build/build/workspace/plugins/or g.eclipse.buckminster.core/src/java/org/eclipse/buckminster/ core/metadata/model/UnresolvedNode.java, line 33: Unnecessary @SuppressWarnings("hiding")
> [java] Warning: file /home/clitte/test_workspace/build/build/workspace/plugins/or g.eclipse.buckminster.core/src/java/org/eclipse/buckminster/ core/metadata/model/ResolvedNode.java, line 42: Unnecessary @SuppressWarnings("hiding")
> [java] Warning: file /home/clitte/test_workspace/build/build/workspace/plugins/or g.eclipse.buckminster.core/src/java/org/eclipse/buckminster/ core/metadata/model/GeneratorNode.java, line 37: Unnecessary @SuppressWarnings("hiding")
> [java] Warning: file /home/clitte/test_workspace/build/build/workspace/plugins/or g.eclipse.buckminster.core/src/java/org/eclipse/buckminster/ core/metadata/model/BillOfMaterials.java, line 52: Unnecessary @SuppressWarnings("hiding")
> [java] Warning: file /home/clitte/test_workspace/build/build/workspace/plugins/or g.eclipse.buckminster.core/src/java/org/eclipse/buckminster/ core/cspec/model/Prerequisites.java, line 20: Unnecessary @SuppressWarnings("hiding")
> [java] Warning: file /home/clitte/test_workspace/build/build/workspace/plugins/or g.eclipse.buckminster.core/src/java/org/eclipse/buckminster/ core/cspec/model/ComponentRequest.java, line 36: Unnecessary @SuppressWarnings("hiding")
> [java] Warning: file /home/clitte/test_workspace/build/build/workspace/plugins/or g.eclipse.buckminster.core/src/java/org/eclipse/buckminster/ core/common/parser/ReplaceHandler.java, line 36: Unnecessary @SuppressWarnings("hiding")
> [java] Warning: file /home/clitte/test_workspace/build/build/workspace/plugins/or g.eclipse.buckminster.ant/plugin.xml, line 29: Referenced class 'org.eclipse.buckminster.ant.taskdefs.WorkspaceBind' in attribute 'class' is not on the plug-in classpath
> [java] Warning: file /home/clitte/test_workspace/build/build/workspace/plugins/or g.eclipse.buckminster.ant/plugin.xml, line 33: Referenced class 'org.eclipse.buckminster.ant.taskdefs.Perform' in attribute 'class' is not on the plug-in classpath
> [java] Warning: file /home/clitte/test_workspace/build/build/workspace/plugins/or g.eclipse.buckminster.ant/plugin.xml, line 35: Referenced class 'org.eclipse.buckminster.ant.taskdefs.Copy' in attribute 'class' is not on the plug-in classpath
> [java] Warning: file /home/clitte/test_workspace/build/build/workspace/plugins/or g.eclipse.buckminster.ant/plugin.xml, line 39: Referenced class 'org.eclipse.buckminster.ant.taskdefs.Delete' in attribute 'class' is not on the plug-in classpath
> [java] Warning: file /home/clitte/test_workspace/build/build/workspace/plugins/or g.eclipse.buckminster.ant/plugin.xml, line 45: Referenced class 'org.eclipse.buckminster.ant.taskdefs.ImportResource' in attribute 'class' is not on the plug-in classpath
> [java] Warning: file /home/clitte/test_workspace/build/build/workspace/plugins/or g.eclipse.buckminster.ant/plugin.xml, line 49: Referenced class 'org.eclipse.buckminster.ant.taskdefs.LastTimestamp' in attribute 'class' is not on the plug-in classpath
> [java] Warning: file /home/clitte/test_workspace/build/build/workspace/plugins/or g.eclipse.buckminster.ant/plugin.xml, line 53: Referenced class 'org.eclipse.buckminster.ant.taskdefs.LastRevision' in attribute 'class' is not on the plug-in classpath
> [java] Warning: file /home/clitte/test_workspace/build/build/workspace/plugins/or g.eclipse.buckminster.ant/plugin.xml, line 55: Referenced class 'org.eclipse.buckminster.ant.taskdefs.Jar' in attribute 'class' is not on the plug-in classpath
> [java] Warning: file /home/clitte/test_workspace/build/build/workspace/plugins/or g.eclipse.buckminster.ant/plugin.xml, line 59: Referenced class 'org.eclipse.buckminster.ant.taskdefs.MultiChmod' in attribute 'class' is not on the plug-in classpath
> [java] Warning: file /home/clitte/test_workspace/build/build/workspace/plugins/or g.eclipse.buckminster.ant/plugin.xml, line 65: Referenced class 'org.eclipse.buckminster.ant.taskdefs.Substitute' in attribute 'class' is not on the plug-in classpath
> [java] Warning: file /home/clitte/test_workspace/build/build/workspace/plugins/or g.eclipse.buckminster.ant/plugin.xml, line 71: Referenced class 'org.eclipse.buckminster.ant.taskdefs.ExecuteOn' in attribute 'class' is not on the plug-in classpath
> [java] Warning: file /home/clitte/test_workspace/build/build/workspace/plugins/or g.eclipse.buckminster.ant/plugin.xml, line 75: Referenced class 'org.eclipse.buckminster.ant.taskdefs.VersionQualifier' in attribute 'class' is not on the plug-in classpath
> [java] Warning: file /home/clitte/test_workspace/build/build/workspace/plugins/or g.eclipse.buckminster.ant/plugin.xml, line 79: Referenced class 'org.eclipse.buckminster.ant.taskdefs.SignatureCleaner' in attribute 'class' is not on the plug-in classpath
> [java] Warning: file /home/clitte/test_workspace/build/build/workspace/plugins/or g.eclipse.buckminster.ant/plugin.xml, line 83: Referenced class 'org.eclipse.buckminster.ant.taskdefs.PackageNames' in attribute 'class' is not on the plug-in classpath
> [java] Warning: file /home/clitte/test_workspace/build/build/workspace/plugins/or g.eclipse.buckminster.ant/plugin.xml, line 87: Referenced class 'org.eclipse.buckminster.ant.taskdefs.ResourceLocation' in attribute 'class' is not on the plug-in classpath
> [java] Warning: file /home/clitte/test_workspace/build/build/workspace/plugins/or g.eclipse.buckminster.ant/plugin.xml, line 91: Referenced class 'org.eclipse.buckminster.ant.taskdefs.ComponentVersion' in attribute 'class' is not on the plug-in classpath
> [java] Warning: file /home/clitte/test_workspace/build/build/workspace/plugins/or g.eclipse.buckminster.ant/plugin.xml, line 97: Referenced class 'org.eclipse.buckminster.ant.types.FileSetGroup' in attribute 'class' is not on the plug-in classpath
> [java] Warning: file /home/clitte/test_workspace/build/build/workspace/plugins/or g.eclipse.buckminster.ant/plugin.xml, line 101: Referenced class 'org.eclipse.buckminster.ant.types.ValueFileSet' in attribute 'class' is not on the plug-in classpath
> [java] Warning: file /home/clitte/test_workspace/build/build/workspace/plugins/or g.eclipse.buckminster.ant/plugin.xml, line 105: Referenced class 'org.eclipse.buckminster.ant.types.ValuePath' in attribute 'class' is not on the plug-in classpath
> [java] Warning: file /home/clitte/test_workspace/build/build/workspace/plugins/or g.eclipse.buckminster.ant/plugin.xml, line 109: Referenced class 'org.eclipse.buckminster.ant.types.Path' in attribute 'class' is not on the plug-in classpath
> [java] Warning: file /home/clitte/test_workspace/build/build/workspace/plugins/or g.eclipse.buckminster.ant/plugin.xml, line 113: Referenced class 'org.eclipse.buckminster.ant.taskdefs.condition.AntCallSucce ss' in attribute 'class' is not on the plug-in classpath
> [java] Warning: file /home/clitte/test_workspace/build/build/workspace/plugins/or g.eclipse.buckminster.jdt/src/java/org/eclipse/buckminster/j dt/internal/ClasspathReader.java, line 43: Unnecessary @SuppressWarnings("hiding")
> [java] Warning: file /home/clitte/test_workspace/build/build/workspace/plugins/or g.eclipse.buckminster.pde/plugin.xml, line 86: Referenced resource 'ant_tasks/ant_tasks.jar' in attribute 'library' cannot be found
> [java] Warning: file /home/clitte/test_workspace/build/build/workspace/plugins/or g.eclipse.buckminster.pde/plugin.xml, line 90: Referenced resource 'ant_tasks/ant_tasks.jar' in attribute 'library' cannot be found
> [java] Warning: file /home/clitte/test_workspace/build/build/workspace/plugins/or g.eclipse.buckminster.pde/plugin.xml, line 98: Referenced resource 'ant_tasks/ant_tasks.jar' in attribute 'library' cannot be found
> [java] Warning: file /home/clitte/test_workspace/build/build/workspace/plugins/or g.eclipse.buckminster.pde/plugin.xml, line 110: Referenced resource 'ant_tasks/ant_tasks.jar' in attribute 'library' cannot be found
> [java] Warning: file /home/clitte/test_workspace/build/build/workspace/plugins/or g.eclipse.buckminster.pde/build.properties, line 18: The folder "ant_tasks/" does not exist in the workspace
> [java] Warning: file /home/clitte/test_workspace/build/build/workspace/plugins/or g.eclipse.buckminster.test/src/org/eclipse/buckminster/test/ junit/TestRunner.java, line 206: Unnecessary @SuppressWarnings("hiding")
> [java] Warning: file /home/clitte/test_workspace/build/build/workspace/plugins/or g.tigris.subversion.clientadapter: build.properties does not exist
> [java] Warning: file /home/clitte/test_workspace/build/build/workspace/plugins/or g.tigris.subversion.clientadapter/META-INF/MANIFEST.MF, line 12: The 'Eclipse-LazyStart' header is deprecated, use 'Bundle-ActivationPolicy'
> [java] Warning: file /home/clitte/test_workspace/build/build/workspace/plugins/or g.tigris.subversion.subclipse.core: build.properties does not exist
> [java] Warning: file /home/clitte/test_workspace/build/build/workspace/plugins/or g.tigris.subversion.subclipse.core/META-INF/MANIFEST.MF, line 25: The 'Eclipse-LazyStart' header is deprecated, use 'Bundle-ActivationPolicy'
> [java] Warning: file /home/clitte/test_workspace/build/build/workspace/plugins/or g.tmatesoft.svnkit: build.properties does not exist
> [java] Warning: file /home/clitte/test_workspace/build/build/workspace/plugins/or g.tmatesoft.svnkit/META-INF/MANIFEST.MF, line 52: Bundle 'com.sun.jna' cannot be resolved
> [java] Warning: file /home/clitte/test_workspace/build/build/workspace/plugins/or g.tigris.subversion.clientadapter.svnkit: build.properties does not exist
> [java] Warning: file /home/clitte/test_workspace/build/build/workspace/plugins/or g.tigris.subversion.clientadapter.svnkit/META-INF/MANIFEST.M F, line 1: No required execution environment has been set
> [java] Warning: file /home/clitte/test_workspace/build/build/workspace/plugins/or g.tigris.subversion.clientadapter.svnkit/META-INF/MANIFEST.M F, line 10: The 'Eclipse-LazyStart' header is deprecated, use 'Bundle-ActivationPolicy'
> [java] Doing full workspace refresh
> [java] Waiting for jobs to end
Re: Automated build broken [message #27060 is a reply to message #27017] |
Mon, 03 November 2008 12:07  |
Hi Guillaume,
Is the build hanging for you? It looks like has gone to the end of the
materialisation process and then stopped.
I saw problems like this when using the subclipse svn adapator and
subsequently switched to subversive.
Grab me on skype or aim (aim) and we can take a closer look.
A.
Guillaume Chatelet wrote:
> Hi Adrian,
> script :)
> Guillaume
>> buckminster.build:
>> [java] ... 59 more
>> [java] ... 64 more
Current Time: Thu Aug 28 19:29:49 EDT 2025
Powered by FUDForum. Page generated in 0.04544 seconds
