OSGi: Registering AbstractURLStreamHandlerService [message #272276] |
Tue, 21 September 2004 16:09  |
I'm having some trouble with a class that derives from
AbstractURLStreamHandlerService and am trying to understand what else might
need to be registered.
1) So far, I perform the following in my plugin and run a JUnit PDE test:
public void start(BundleContext context) throws Exception {
super.start(context);
Hashtable properties = new Hashtable(1);
properties.put(URLConstants.URL_HANDLER_PROTOCOL, new String[] {"epfs"});
context.registerService(
URLStreamHandlerService.class.getName(),
new OSGiFileServerURLStreamHandler(),
properties
This appears to work fine until the point where I need to parse the
InputStream associated with the URL response:
ListAllAction get = new ListAllAction(connection);
get.exec(null);
InputStream stream = get.getContents();
// Just a test to ensure that the plugin and class is being loaded
FileServerFile dummy = new FileServerFile( );
ExceptionListener listener = new ExceptionListener() {
public void exceptionThrown(Exception e) {
e.printStackTrace(); // Extract printed below
// Throws an exception (see below)
// The target class cannot be found which is my FileServerFile class
XMLDecoder decoder = new XMLDecoder(stream, null, listener);
Object o = decoder.readObject();
try {
stream.close();
} catch (IOException e) {
// TODO Auto-generated catch block
connection.close();
2) Now if I run the same code but within a simple JUnit test without
invoking the platform while also registering my URLStreamHandler as follows:
URL.setURLStreamHandlerFactory( MyOwnURLStreamHandlerFactory);
Everything works fine and I'm able to parse the response from the URL
request.
Hope this is enough info to start with.
thx
Paul
I get the following exception from the XMLDecoder constructor call above:
at java.beans.Statement.invoke(Statement.java:454)
at java.beans.Expression.getValue(Expression.java:101)
at java.beans.ObjectHandler.getValue(XMLDecoder.java:241)
at java.beans.ObjectHandler.endElement(XMLDecoder.java:453)
org.xml.sax.helpers.XMLReaderAdapter.endElement(XMLReaderAda pter.java:353)
at org.apache.crimson.parser.Parser2.maybeElement(Parser2.java: 1536)
at org.apache.crimson.parser.Parser2.content(Parser2.java:1779)
at org.apache.crimson.parser.Parser2.maybeElement(Parser2.java: 1507)
at org.apache.crimson.parser.Parser2.parseInternal(Parser2.java :500)
at org.apache.crimson.parser.Parser2.parse(Parser2.java:305)
at org.apache.crimson.parser.XMLReaderImpl.parse(XMLReaderImpl. java:442)
at org.xml.sax.helpers.XMLReaderAdapter.parse(XMLReaderAdapter. java:223)
at javax.xml.parsers.SAXParser.parse(SAXParser.java:314)
at javax.xml.parsers.SAXParser.parse(SAXParser.java:89)
at java.beans.XMLDecoder.<init>(XMLDecoder.java:88)
Re: Registering AbstractURLStreamHandlerService [message #272655 is a reply to message #272598] |
Fri, 24 September 2004 12:02   |
No, I checked the porting guide at:
http://dev.eclipse.org/viewcvs/index.cgi/~checkout~/org.ecli pse.platform.doc.isv/porting/incompatibilities.html#URL%20st ream%20handler%20extensions
and then I only looked at org.eclipse.osgi.framework.internal.core.Framework
and org.eclipse.osgi.framework.internal.protocl.StreamHandlerFac tory. But
I'll check it out, thanks for the reply and I'll let you know what I find
out.
paul
"Pascal Rapicault" <pascal@ibm.canada> wrote in message
news:civpn0$ata$1@eclipse.org...
> Did you have a look at PlatformURLHandler, and other subclasses of this
> being shipped in eclipse?
> You might be miising the implementation of a callback?
> PaScaL
> Paul Wuethrich wrote:
> > Anyone get this message yet??
> > "Paul Wuethrich" <paul.wuethrich@eye-ris.com> wrote in message
> > news:ciq1gu$1ub$1@eclipse.org...
> > might
test:
> > {"epfs"});
> >> properties
> >> get.exec(null);
> >> try {
> >> stream.close();
> >> connection.close();
> > follows:
> >>request.
> >>thx
> >>Paul
above:
> >>java.lang.NullPointerException
> >>at
Re: Registering AbstractURLStreamHandlerService [message #272982 is a reply to message #272799] |
Wed, 29 September 2004 12:47  |
Pascal,
It looks like there's a problem with ourURL client library so the code below
is definitely ok.
thanks again.
Paul
news:cj9s4q$4r2$1@eclipse.org...
> I don't see anything special being done in that class hierarchy. So based
> on what I included below is it safe to assume that what I'm doing "should"
> work??
> thx
> Paul
> > PaScaL
> > > might
> test:
> > > {"epfs"});
> > >> properties
> > >> get.exec(null);
> > >> try {
> > >> stream.close();
> > >> connection.close();
> > > follows:
> > >>request.
> > >>thx
> > >>Paul
> above:
> > >>at
> > >>at
> > >>at
FUDForum. Page generated in 0.08432 seconds
