Home » Newcomers » Newcomers » src compile eclipse ide
src compile eclipse ide [message #272244] Wed, 15 July 2009 10:01 Go to next message
do we need jdk 1.4, 1.5 and 1.6 all installed on our system to be able to
source compile eclipse ide classic platform src ? I have situation the
build not being able to find even String class and generates lots of
errors when trying to build on opensolaris 64bit on intel using jdk1.6
update 14. I assume it does 32 bit compile only as eclipse build args
does not give 64bit option but may be by default it will do it 64bit.
Miten.
Re: src compile eclipse ide [message #272271 is a reply to message #272244] Thu, 16 July 2009 09:39 Go to previous messageGo to next message
Miten Mehta wrote:
> to source compile eclipse ide classic platform src ?
Is this with or without the Java IDE stuff/code? If so, 1.4 should be
sufficient.
Dani
> I have situation the build not being able to find even String class
> and generates lots of errors when trying to build on opensolaris 64bit
> on intel using jdk1.6 update 14. I assume it does 32 bit compile only
> as eclipse build args does not give 64bit option but may be by default
> Miten.
Re: src compile eclipse ide [message #272285 is a reply to message #272271] Thu, 16 July 2009 12:37 Go to previous message
opensolaris does not have jdk 1.4 on its distro site. I have only 1.5 and
1.6. In the build.properties file that comes in srcIncluded src zip I set
jdk1.4, 1.5 and 1.6 related setting to point to same jdk1.6 instance jars.
I think I dont need to even set them as instructions mention that its
needed only if cross compiling. I started to add them since w/o that it
gave same errors. I think is has to do with java.security.cert packages
which in old jdk1.4 was actually javax and the eclipse src uses old javax.
I have also download the srcFetch zip. should it be helpful to resolve
the issue? I wonder though why amongst 10000 errors it also mentions
things like cannot find String class.
Miten.
Previous Topic:scripting eclipse
Next Topic:Is Simple Syntax Highlighting Possible?
Current Time: Thu Nov 27 04:04:12 EST 2025
Powered by FUDForum. Page generated in 0.48585 seconds
