Home » Archived » GEF3D » Problem getting Draw3d to draw something
Problem getting Draw3d to draw something [message #2286] Sun, 12 April 2009 20:28 Go to next message
--------------040800040307000704080608
Content-Type: text/plain; charset=ISO-8859-15
I tried to wrap my head around Draw3d a bit and play around with it but
didn't managed to get a simple example working (I simply wanted to draw
a rectangle).
Could someone please correct the code from below for me?
Tom
name="View.java"
Content-Disposition: inline;
filename="View.java"
cGFja2FnZSB0ZXN0M2Q7CgppbXBvcnQgb3JnLmVjbGlwc2UuZHJhdzJkLkZp Z3VyZTsKaW1w
b3J0IG9yZy5lY2xpcHNlLmRyYXcyZC5HcmFwaGljczsKaW1wb3J0IG9yZy5l Y2xpcHNlLmRy
YXcyZC5MaWdodHdlaWdodFN5c3RlbTsKaW1wb3J0IG9yZy5lY2xpcHNlLmRy YXcyZC5YWUxh
eW91dDsKaW1wb3J0IG9yZy5lY2xpcHNlLmRyYXcyZC5nZW9tZXRyeS5Qb2lu dDsKaW1wb3J0
IG9yZy5lY2xpcHNlLmRyYXczZC5EcmF3M0RDYW52YXM7CmltcG9ydCBvcmcu ZWNsaXBzZS5k
cmF3M2QuRmlndXJlM0Q7CmltcG9ydCBvcmcuZWNsaXBzZS5kcmF3M2QuTGln aHR3ZWlnaHRT
eXN0ZW0zRDsKaW1wb3J0IG9yZy5lY2xpcHNlLmRyYXczZC5SZW5kZXJDb250 ZXh0OwppbXBv
cnQgb3JnLmVjbGlwc2UuZHJhdzNkLlhZWkxheW91dDsKaW1wb3J0IG9yZy5l Y2xpcHNlLnN3
dC5TV1Q7CmltcG9ydCBvcmcuZWNsaXBzZS5zd3QubGF5b3V0LkZpbGxMYXlv dXQ7CmltcG9y
dCBvcmcuZWNsaXBzZS5zd3Qud2lkZ2V0cy5DYW52YXM7CmltcG9ydCBvcmcu ZWNsaXBzZS5z
d3Qud2lkZ2V0cy5Db21wb3NpdGU7CmltcG9ydCBvcmcuZWNsaXBzZS51aS5w YXJ0LlZpZXdQ
YXJ0OwoKcHVibGljIGNsYXNzIFZpZXcgZXh0ZW5kcyBWaWV3UGFydCB7Cglw dWJsaWMgc3Rh
dGljIGZpbmFsIFN0cmluZyBJRCA9ICJUZXN0M0QudmlldyI7CgoJLyoqCgkg KiBUaGlzIGlz
IGEgY2FsbGJhY2sgdGhhdCB3aWxsIGFsbG93IHVzIHRvIGNyZWF0ZSB0aGUg dmlld2VyIGFu
ZCBpbml0aWFsaXplCgkgKiBpdC4KCSAqLwoJcHVibGljIHZvaWQgY3JlYXRl UGFydENvbnRy
b2woQ29tcG9zaXRlIHBhcmVudCkgewoJCUNvbXBvc2l0ZSBjID0gbmV3IENv bXBvc2l0ZShw
YXJlbnQsU1dULk5PTkUpOwoJCWMuc2V0TGF5b3V0KG5ldyBGaWxsTGF5b3V0 KCkpOwoJCWRy
YXcyZChjKTsKCQlkcmF3M2QoYyk7Cgl9CgkKCXByaXZhdGUgdm9pZCBkcmF3 MmQoQ29tcG9z
aXRlIHBhcmVudCkgewoJCUNhbnZhcyBjdnMgPSBuZXcgQ2FudmFzKHBhcmVu dCxTV1QuRE9V
QkxFX0JVRkZFUkVEKTsKCQljdnMuc2V0QmFja2dyb3VuZChwYXJlbnQuZ2V0 RGlzcGxheSgp
LmdldFN5c3RlbUNvbG9yKFNXVC5DT0xPUl9SRUQpKTsKCQlMaWdodHdlaWdo dFN5c3RlbSBs
d3MgPSBuZXcgTGlnaHR3ZWlnaHRTeXN0ZW0oY3ZzKTsKCQlGaWd1cmUgcm9v dEZpZ3VyZSA9
IG5ldyBGaWd1cmUoKTsKCQlyb290RmlndXJlLnNldEJhY2tncm91bmRDb2xv cihwYXJlbnQu
Z2V0RGlzcGxheSgpLmdldFN5c3RlbUNvbG9yKFNXVC5DT0xPUl9HUkVFTikp OwoJCQoJCUZp
Z3VyZSByZWN0ID0gbmV3IEZpZ3VyZSgpIHsKCQkJQE92ZXJyaWRlCgkJCXBy b3RlY3RlZCB2
b2lkIHBhaW50RmlndXJlKEdyYXBoaWNzIGdyYXBoaWNzKSB7CgkJCQlncmFw aGljcy5zZXRC
YWNrZ3JvdW5kQ29sb3IoZ2V0QmFja2dyb3VuZENvbG9yKCkpOwoJCQkJZ3Jh cGhpY3MuZmls
bFJlY3RhbmdsZShnZXRCb3VuZHMoKSk7CgkJCX0KCQl9OwoJCXJlY3Quc2V0 QmFja2dyb3Vu
ZENvbG9yKHBhcmVudC5nZXREaXNwbGF5KCkuZ2V0U3lzdGVtQ29sb3IoU1dU LkNPTE9SX0JM
VUUpKTsKCQlyZWN0LnNldExvY2F0aW9uKG5ldyBQb2ludCgyMCwyMCkpOwoJ CXJlY3Quc2V0
U2l6ZSgxMDAsIDEwMCk7CgkJcm9vdEZpZ3VyZS5hZGQocmVjdCk7CgkJCgkJ cm9vdEZpZ3Vy
ZS5zZXRMYXlvdXRNYW5hZ2VyKG5ldyBYWUxheW91dCgpKTsKCQlsd3Muc2V0 Q29udGVudHMo
cm9vdEZpZ3VyZSk7Cgl9CgkKCXByaXZhdGUgdm9pZCBkcmF3M2QoQ29tcG9z aXRlIHBhcmVu
dCkgewoJCUxpZ2h0d2VpZ2h0U3lzdGVtM0QgbHdzID0gbmV3IExpZ2h0d2Vp Z2h0U3lzdGVt
M0QoKTsKCQlGaWd1cmUzRCByb290RmlndXJlID0gbmV3IEZpZ3VyZTNEKCkg ewoJCQlAT3Zl
cnJpZGUKCQkJcHJvdGVjdGVkIHZvaWQgcGFpbnRGaWd1cmUoR3JhcGhpY3Mg aUdyYXBoaWNz
KSB7CgkJCQlzdXBlci5wYWludEZpZ3VyZShpR3JhcGhpY3MpOwoJCQkJU3lz dGVtLmVyci5w
cmludGxuKCJSb290IFBhaW50IGlzIGNhbGxlZCIpOwoJCQl9CgkJCQoJCQlA T3ZlcnJpZGUK
CQkJcHVibGljIHZvaWQgcmVuZGVyKFJlbmRlckNvbnRleHQgcmVuZGVyQ29u dGV4dCkgewoJ
CQkJc3VwZXIucmVuZGVyKHJlbmRlckNvbnRleHQpOwoJCQkJU3lzdGVtLmVy ci5wcmludGxu
KCJSb290IFJlbmRlciBpcyBjYWxsZWQiKTsKCQkJfQoJCX07CgkJcm9vdEZp Z3VyZS5zZXRC
YWNrZ3JvdW5kQ29sb3IocGFyZW50LmdldERpc3BsYXkoKS5nZXRTeXN0ZW1D b2xvcihTV1Qu
Q09MT1JfR1JFRU4pKTsKCQkKCQlGaWd1cmUzRCByZWN0ID0gbmV3IEZpZ3Vy ZTNEKCkgewoJ
CQlAT3ZlcnJpZGUKCQkJcHJvdGVjdGVkIHZvaWQgcGFpbnRGaWd1cmUoR3Jh cGhpY3MgaUdy
YXBoaWNzKSB7CgkJCQlzdXBlci5wYWludEZpZ3VyZShpR3JhcGhpY3MpOwoJ CQkJU3lzdGVt
LmVyci5wcmludGxuKCJSZWN0IFBhaW50IGlzIGNhbGxlZCIpOwoJCQl9CgkJ CQoJCQlAT3Zl
cnJpZGUKCQkJcHVibGljIHZvaWQgcmVuZGVyKFJlbmRlckNvbnRleHQgcmVu ZGVyQ29udGV4
dCkgewoJCQkJc3VwZXIucmVuZGVyKHJlbmRlckNvbnRleHQpOwoJCQkJU3lz dGVtLmVyci5w
cmludGxuKCJSZWN0IFJlbmRlciBpcyBjYWxsZWQiKTsKCQkJfQoJCX07CgkJ cmVjdC5zZXRC
Q09MT1JfQkxVRSkpOwoJCXJlY3Quc2V0TG9jYXRpb24obmV3IFBvaW50KDIw LDIwKSk7CgkJ
cmVjdC5zZXRTaXplKDEwMCwgMTAwKTsKCQlyb290RmlndXJlLmFkZChyZWN0 KTsKCQkKCQly
b290RmlndXJlLnNldExheW91dE1hbmFnZXIobmV3IFhZWkxheW91dCgpKTsK CQlsd3Muc2V0
Q29udGVudHMocm9vdEZpZ3VyZSk7CgkJCgkJRHJhdzNEQ2FudmFzIGN2cyA9 IERyYXczRENh
bnZhcy5jcmVhdGVDYW52YXMocGFyZW50LCBTV1QuTk9ORSwgbHdzKTsKCQlj dnMuc2V0QmFj
a2dyb3VuZChwYXJlbnQuZ2V0RGlzcGxheSgpLmdldFN5c3RlbUNvbG9yKFNX VC5DT0xPUl9E
QVJLX1JFRCkpOwoKCX0KCgkvKioKCSAqIFBhc3NpbmcgdGhlIGZvY3VzIHJl cXVlc3QgdG8g
dGhlIHZpZXdlcidzIGNvbnRyb2wuCgkgKi8KCXB1YmxpYyB2b2lkIHNldEZv Y3VzKCkgewoJ
CQoJfQp9
--------------040800040307000704080608--
Re: Problem getting Draw3d to draw something [message #2318 is a reply to message #2286] Mon, 13 April 2009 08:03 Go to previous message
Hi Tom,
frankly we haven't yet tested or used Draw3D "outside" GEF3D. I have
created a view in the graph example which uses Draw3D without GEF3D:
org.eclipse.gef3d.examples.graph.editor.Draw3DViewPart. You simply have
to update the graph example and test the view in action. Since no
camera tool is provided, you cannot move around of course. But at least
you could get an impression on how to initialize the Draw3DCanvas and
the LightweightSystem3D. This will hopefully help.
Cheers
Jens
For your convenience, here is the initialization snippet from the
example. The initial camera position is set to look at (0,0,0) from
(0,0,-1000). See my posting on April 1st (Re: Draw3d Program) for
details about that.
public void createPartControl(Composite parent) {
// some composite
Composite c = new Composite(parent,SWT.NONE);
c.setLayout(new FillLayout());
// create a Draw3DCanvas inside:
LightweightSystem3D lws3D = new LightweightSystem3D();
lws3D.setDrawAxes(true);
canvas = Draw3DCanvas.createCanvas(c, SWT.NONE,
lws3D);
lws3D.setControl(canvas);
// create some figures:
// set content of lightweight system:
lws3D.setContents(graphFigure);
Re: Problem getting Draw3d to draw something [message #561234 is a reply to message #2286] Mon, 13 April 2009 08:03 Go to previous message
Hi Tom,
Cheers
Jens
details about that.
// some composite
lws3D);
Previous Topic:Problem getting Draw3d to draw something
Next Topic:Signature of IFigure3D.render(..) and other similar methods changed
Current Time: Sat Nov 08 10:40:56 EST 2025
Powered by FUDForum. Page generated in 0.03537 seconds
