Home » Newcomers » Newcomers » Synchronization between multiple PCs
Synchronization between multiple PCs [message #272107] Fri, 10 July 2009 14:39 Go to next message
Hi NG,
I changed my company and now I'm confronted with the problem that I've to
sync a project (or better a workspace) between three PCs. Well I know the
first Idea sounds like "just use subversion". Generally I would agree, but
in this specific case I'm quiet unsure. One edge condition is that the
project already uses a subversion connection which many developers use. So
it's out of the question that I flood the public subversion with my "syncs".
Is there a better way to sync such a project or is it possible that I set a
private subversion instance on my main pc up and commit the project to both
repos? What could be the best way?
Kind regards,
Patrick Trübe
Re: Synchronization between multiple PCs [message #272279 is a reply to message #272107] Thu, 16 July 2009 10:20 Go to previous message
Patrick Truebe wrote:
> Hi NG,
> to sync a project (or better a workspace) between three PCs. Well I know
> the first Idea sounds like "just use subversion". Generally I would
> agree, but in this specific case I'm quiet unsure. One edge condition
> is that the project already uses a subversion connection which many
> developers use. So it's out of the question that I flood the public
> subversion with my "syncs". Is there a better way to sync such a project
> or is it possible that I set a private subversion instance on my main pc
> up and commit the project to both repos? What could be the best way?
> Kind regards,
> Patrick Trübe
You might start at http://en.wikipedia.org/wiki/File_synchronization.
Previous Topic:version numbers in about box for Java application on Mac OS X
Next Topic:scripting eclipse
Current Time: Wed Nov 19 15:23:37 EST 2025
Powered by FUDForum. Page generated in 0.08903 seconds
