Home » Newcomers » Newcomers » swt documentation locally
swt documentation locally [message #271976] Sat, 04 July 2009 13:36 Go to next message
I just installed eclipse-jee-galileo-win32.zip. I'd like to use the SWT
and would like to have it's documentation locally on my PC. I found it
online in the Platform Plug-in Developer Guide chapter of the
documentation, which does not seem to be available locally on my
installation.
I searched for quite a while now but only end up at the online
documentation. Only one article told me that by installing the
corresponding package I'll get the documentation locally. The
corresponding package, however, seems to be already part of
eclipse-jee-galileo-win32.zip. When I try to install it I get some message
it's already there and the documentation is still not available locally.
Any hint?
TIA,
Thomas
Re: swt documentation locally [message #272032 is a reply to message #271976] Tue, 07 July 2009 08:01 Go to previous messageGo to next message
Thomas Nehring wrote:
> SWT and would like to have it's documentation locally on my PC. I
> found it online in the Platform Plug-in Developer Guide chapter of the
> installation.
Do you mean the Javadoc? Normally, if you use PDE you should see the
source automatically.
Dani
> message it's already there and the documentation is still not
> available locally. Any hint?
> TIA,
> Thomas
Re: swt documentation locally [message #272034 is a reply to message #271976] Tue, 07 July 2009 08:48 Go to previous message
Originally posted by: groups.pellaton.li
Hello
The whole documentation you are seeing online is shipped along with
Eclipse too. However, the files are packed into several OSGi bundles
of which each contains parts of the documentation.
The preferred way to access the doc is to use Eclipse's help center.
Or you may unpack the following jars (all located in the plugins
directory):
org.eclipse.gef.doc.isv_3.5.0.v20090422-2346.jar
org.eclipse.jdt.doc.isv_3.5.0.v20090603-1530.jar
org.eclipse.platform.doc.isv_3.5.0.v20090611.jar
org.eclipse.datatools.doc.isv_1.6.0.200806091108.jar
org.eclipse.draw2d.doc.isv_3.5.0.v20090422-2346.jar
The API doc in there is a standard JavaDoc documentation and easily
browsable. The guides are there, but they lack the index and search
functionality as these functions are normally handled by the help
center.
A third option is to run the so called info center locally. For more
information about that possibility, please refer to:
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/ua_help_setup_infocenter.htm
HTH
Michael Pellaton
Previous Topic:Where is a clear doc on details of the JUnit view?
Next Topic:Select Multiple items in Common Navigator
Current Time: Tue Jul 22 13:05:50 EDT 2025
Powered by FUDForum. Page generated in 0.35413 seconds
