Home » Newcomers » Newcomers » orphaned connector
orphaned connector [message #271969] Fri, 03 July 2009 15:14
Hi I've imported a war file which contains several projects, 3
calldesign.xml files and 2 calldesign.frag.
I can open every file except one of the calldesign.frag files. I get an
orphaned connector error.
Any idea what this could be? I've checked out this news group and did some
googling to no avail.
Here's the full Exception:
java.lang.RuntimeException: orphaned connector:
id=d13df3d457844dbaaac5b85966a47601
origin=c0e75e56c8804d559666f7a953d839a6
destination=aae216cd474b45c99cdfdd63b1fb0ad7
at org.eclipse.vtp.desktop.model.core.Connector.<init>(Connector.java:53)
at org.eclipse.vtp.desktop.model.core.Model.<init>(Model.java:102)
org.eclipse.vtp.desktop.editors.core.impl.ApplicationFragmen tEditor.init(ApplicationFragmentEditor.java:198)
org.eclipse.ui.internal.EditorManager.createSite(EditorManag er.java:794)
org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:643)
org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:426)
org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:592)
org.eclipse.ui.internal.EditorAreaHelper.setVisibleEditor(Ed itorAreaHelper.java:263)
org.eclipse.ui.internal.EditorManager.setVisibleEditor(Edito rManager.java:1405)
org.eclipse.ui.internal.EditorManager$5.runWithException(Edi torManager.java:939)
org.eclipse.ui.internal.StartupThreading$StartupRunnable.run (StartupThreading.java:31)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:129)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3659)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3296)
org.eclipse.ui.application.WorkbenchAdvisor.openWindows(Work benchAdvisor.java:801)
org.eclipse.ui.internal.Workbench$25.runWithException(Workbe nch.java:1342)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2309)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:169)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 508)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:447)
at org.eclipse.equinox.launcher.Main.run(Main.java:1173)
Previous Topic:policytool
Next Topic:env debugging
Current Time: Thu Nov 20 11:55:35 EST 2025
Powered by FUDForum. Page generated in 0.07242 seconds
