Home » Archived » Maven Integration (M2E) » [tycho] build problem (org.eclipse.jdt.core)
[tycho] build problem (org.eclipse.jdt.core) [message #26914] Fri, 22 May 2009 09:23 Go to next message
Hi!
I am currently experimenting with building Eclipse PDE components with
Tycho. I could easily run the example and do some of my own examples as
well. Now I want to build org.eclipse.jdt.core (checked out HEAD source
from dev.eclipse.org:/cvsroot/eclipse CVS).
My problem is with the ant "dependency". This dependency is added using
build.properties:
" jars.extra.classpath=platform:/plugin/org.apache.ant/lib/ant .jar " - not
using MANIFEST.MF. The "mvn package" command starts the process as it
should, but the compilation fails with "The import org.apache cannot be
resolved" error messages.
I've tried adding the ant dependency manually using dependencyManagement:
<dependency>
<groupId>org.apache.ant</groupId>
<artifactId>org.apache.ant</artifactId>
<version>1.7.0</version>
<type>eclipse-plugin</type>
</dependency>
But this doesn't help either. Can somebody help me how to add
dependencies manually?
Andras.
Re: [tycho] build problem (org.eclipse.jdt.core) [message #26953 is a reply to message #26914] Fri, 22 May 2009 18:22 Go to previous messageGo to next message
Originally posted by: igor.ifedorenko.com
Andras,
This is what I use to build p2-related Tycho projects (see [1] for the
full pom)
<build>
<plugins>
<plugin>
<groupId>org.codehaus.tycho</groupId>
<artifactId>maven-osgi-compiler-plugin</artifactId>
<configuration>
<extraClasspathElements>
<extraClasspathElement>
<groupId>org.sonatype.tycho</groupId>
<artifactId>tycho-p2-facade</artifactId>
<version>${project.version}</version>
</extraClasspathElement>
</extraClasspathElements>
</configuration>
</plugin>
</plugins>
</build>
This works with (unannounced) 0.3.0-DEV-2146 and current 0.4.0 builds
but I am not sure we will keep this syntax long term.
Please open enhancement request in JIRA [2] if you need Tycho to honour
jars.extra.classpath from build.properties.
[1]
https://svn.sonatype.org/m2eclipse/tycho/trunk/tycho-p2/org. sonatype.tycho.p2.impl/pom.xml
[2] https://issues.sonatype.org/browse/MNGECLIPSE
Igor
Andras Milasisn wrote:
> Hi!
> build.properties:
> <dependency>
> </dependency>
> Andras.
Re: [tycho] build problem (org.eclipse.jdt.core) [message #27074 is a reply to message #26953] Tue, 26 May 2009 07:56 Go to previous message
Hi Igor,
I've tried you're suggestion. I've added the following lines to the pom:
<build>
<plugins>
<plugin>
<configuration>
<artifactId>ant</artifactId>
</configuration>
</plugin>
</plugins>
</build>
I've tried to run it, but got the following exception (it's missing the
parent pom file, it has no problem if I add ant as a dependency):
[DEBUG] Parent pom ids do not match: Parent File =
K:\DeepTest\Workspace\org.eclipse.jdt.core (head)\pom.xml, Parent ID =
dt:org.eclipse.jdt.core:3.5.0.qualifier, Child ID =
org.apache.ant:ant:1.7.0, Expected Parent ID =
org.apache.ant:ant-parent:pom:1.7.0
[ERROR]
Internal error in the plugin manager executing goal
'org.codehaus.tycho:maven-osgi-compiler-plugin:0.4.0-DEV-223 3:compile':
Mojo execution failed.
Any suggestion why does it want to use the jdt.core's pom as parent?
I've tried some tricks I could come up with, but nothing helped so far.
I've tried both 0.3.0-DEV-2146 and 0.4.0-DEV-2233 releases.
Andras.
Igor Fedorenko wrote:
> Andras,
> full pom)
> <build>
> <plugins>
> <plugin>
> <configuration>
> </configuration>
> </plugin>
> </plugins>
> </build>
> [1]
> Igor
>> Hi!
>> as well. Now I want to build org.eclipse.jdt.core (checked out HEAD
>> source from dev.eclipse.org:/cvsroot/eclipse CVS).
>> using build.properties:
>> not using MANIFEST.MF. The "mvn package" command starts the process as
>> it should, but the compilation fails with "The import org.apache
>> cannot be resolved" error messages.
>> <dependency>
>> </dependency>
>> Regards,
>> Andras.
Previous Topic:Files from resource folders?
Next Topic:M2_REPO
Current Time: Thu Jun 05 15:33:02 EDT 2025
Powered by FUDForum. Page generated in 0.03027 seconds
