Home » Eclipse Projects » Eclipse Platform » Install Eclipse 3.0 Win XP
Install Eclipse 3.0 Win XP [message #270975] Fri, 10 September 2004 00:35 Go to next message
Originally posted by: badz_badz.yahoo.com
I download eclipse 3.0 and extract to my PC. After that I try to start and
I got error message "An error has occurred. See the log file
d:\eclipse\configuration\1094706359096.log.". Please help me to fix this.
Log file
!SESSION Sep 09, 2004 12:05:59.424
eclipse.buildId=I200406251208
java.version=1.3.1_01
!ENTRY org.eclipse.osgi Sep 09, 2004 12:05:59.424
!MESSAGE Error registering XML parser services.
!STACK 0
java.lang.ClassNotFoundException: javax.xml.parsers.SAXParserFactory
at java.net.URLClassLoader$1.run(Unknown Source)
at java.net.URLClassLoader.findClass(Unknown Source)
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Unknown Source)
org.eclipse.core.runtime.adaptor.EclipseAdaptor.registerEndo rsedXMLParser(EclipseAdaptor.java:272)
org.eclipse.core.runtime.adaptor.EclipseAdaptor.frameworkSta rt(EclipseAdaptor.java:253)
org.eclipse.osgi.framework.internal.core.SystemBundleActivat or.start(SystemBundleActivator.java:61)
org.eclipse.osgi.framework.internal.core.BundleContextImpl$1 .run(BundleContextImpl.java:958)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:954)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:937)
org.eclipse.osgi.framework.internal.core.StartLevelManager.r esumeBundles(StartLevelManager.java:553)
org.eclipse.osgi.framework.internal.core.StartLevelManager.i ncFWSL(StartLevelManager.java:477)
org.eclipse.osgi.framework.internal.core.StartLevelManager.d oSetStartLevel(StartLevelManager.java:273)
org.eclipse.osgi.framework.internal.core.StartLevelManager.l aunch(StartLevelManager.java:243)
org.eclipse.osgi.framework.internal.core.SystemBundle.resume (SystemBundle.java:166)
org.eclipse.osgi.framework.internal.core.Framework.launch(Fr amework.java:425)
at org.eclipse.osgi.framework.internal.core.OSGi.launch(OSGi.ja va:51)
org.eclipse.core.runtime.adaptor.EclipseStarter.startup(Ecli pseStarter.java:216)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:127)
at java.lang.reflect.Method.invoke(Native Method)
at org.eclipse.core.launcher.Main.basicRun(Main.java:183)
at org.eclipse.core.launcher.Main.run(Main.java:644)
at org.eclipse.core.launcher.Main.main(Main.java:628)
!ENTRY org.eclipse.osgi Sep 09, 2004 12:05:59.487
!MESSAGE Startup error
!STACK 1
java.lang.NoClassDefFoundError: org/xml/sax/helpers/DefaultHandler
at java.lang.ClassLoader.defineClass0(Native Method)
at java.lang.ClassLoader.defineClass(Unknown Source)
at java.security.SecureClassLoader.defineClass(Unknown Source)
at java.net.URLClassLoader.defineClass(Unknown Source)
at java.net.URLClassLoader.access$100(Unknown Source)
org.eclipse.core.runtime.adaptor.PluginConverterImpl.parsePl uginInfo(PluginConverterImpl.java:552)
org.eclipse.core.runtime.adaptor.PluginConverterImpl.fillPlu ginInfo(PluginConverterImpl.java:111)
org.eclipse.core.runtime.adaptor.PluginConverterImpl.convert Manifest(PluginConverterImpl.java:655)
org.eclipse.core.runtime.adaptor.EclipseBundleData.generateM anifest(EclipseBundleData.java:219)
org.eclipse.core.runtime.adaptor.EclipseBundleData.loadManif est(EclipseBundleData.java:177)
org.eclipse.core.runtime.adaptor.EclipseBundleData.getManife st(EclipseBundleData.java:159)
org.eclipse.core.runtime.adaptor.EclipseBundleData.loadFromM anifest(EclipseBundleData.java:266)
org.eclipse.osgi.framework.internal.defaultadaptor.DefaultBu ndleData.initializeNewBundle(DefaultBundleData.java:77)
org.eclipse.osgi.framework.internal.defaultadaptor.DefaultAd aptor$1.begin(DefaultAdaptor.java:451)
org.eclipse.osgi.framework.internal.core.Framework.installWo rkerPrivileged(Framework.java:746)
org.eclipse.osgi.framework.internal.core.Framework$2.run(Fra mework.java:664)
org.eclipse.osgi.framework.internal.core.Framework.installWo rker(Framework.java:715)
org.eclipse.osgi.framework.internal.core.Framework.installBu ndle(Framework.java:659)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.i nstallBundle(BundleContextImpl.java:219)
org.eclipse.core.runtime.adaptor.EclipseStarter.installBundl es(EclipseStarter.java:800)
org.eclipse.core.runtime.adaptor.EclipseStarter.loadBasicBun dles(EclipseStarter.java:429)
org.eclipse.core.runtime.adaptor.EclipseStarter.startup(Ecli pseStarter.java:222)
!ENTRY org.eclipse.osgi Sep 09, 2004 12:05:59.502
!MESSAGE Bundle
initial@reference:file:d:/eclipse/plugins/org.eclipse.core.runtime_3.0.0/
[1] was not resolved.
Re: Install Eclipse 3.0 Win XP [message #270976 is a reply to message #270975] Fri, 10 September 2004 01:58 Go to previous messageGo to next message
<grump>
This is one of the most FAQs around.
Please search the newsgroup before posting questions:
http://www.eclipse.org/search/search.cgi
</grump>
As indicated on the download page, Eclipse requires at least a 1.4.* VM.
You are using a 1.3.1 VM
Use the -vm option to specify the1.4.* VM you wish to use.
HTH
Darins
"Thanes" <badz_badz@yahoo.com> wrote in message
news:chrauu$vid$1@eclipse.org...
> Log file
> BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
> !STACK 0
> at java.security.AccessController.doPrivileged(Native Method)
> at java.lang.ClassLoader.loadClass(Unknown Source)
> at
> at
r.java:253)
> at
> at
xtImpl.java:958)
> at
> at
xtImpl.java:937)
> at
> at
lManager.java:477)
> at
> at
Manager.java:243)
> at
va:166)
> at
> at
216)
> at
> !STACK 1
> at
> at
> at
> at
undleData.java:219)
> at
eData.java:177)
> at
Data.java:159)
> at
undleData.java:266)
> at
> at
> at
ramework.java:746)
> at
> at
ava:715)
> at
ava:659)
> at
> at
r.java:800)
> at
ter.java:429)
> at
222)
> at
> !MESSAGE Bundle
Re: Install Eclipse 3.0 Win XP [message #271079 is a reply to message #270976] Sat, 11 September 2004 04:39 Go to previous message
Is there a way for eclipse to know what version of JVM it runs above?
Tal.
Previous Topic:Pluin giving error java.lang.ClassNotFoundException
Next Topic:Unable to execute eclipse.exe as non-administrator
Current Time: Mon Jul 14 12:05:46 EDT 2025
Powered by FUDForum. Page generated in 0.05819 seconds
