Eclipse hnags as soon as it comes up [message #270958] |
Thu, 09 September 2004 19:38 |
I have Eclipse 3 (GTK) running on RedHat AS3 with the Sun Java version
1.4.1_02. All was working fine, and then suddenly Eclipse starts to hang
the moment I bring it up. It generates a long stacktrace, mostly
repetitive for each currently installed project. Here is an example:
org.eclipse.core.internal.resources.ResourceException: Resource
/AccntManager is not open.
org.eclipse.core.internal.resources.Project.checkAccessible( Project.java:126)
org.eclipse.core.internal.resources.Project.hasNature(Projec t.java:456)
org.epic.core.decorators.PerlDecorator.decorate(PerlDecorato r.java:73)
org.eclipse.ui.internal.decorators.LightweightDecoratorDefin ition.decorate(LightweightDecoratorDefinition.java:155)
org.eclipse.ui.internal.decorators.LightweightDecoratorManag er$LightweightRunnable.run(LightweightDecoratorManager.java: 60)
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java:615)
at org.eclipse.core.runtime.Platform.run(Platform.java:747)
org.eclipse.ui.internal.decorators.LightweightDecoratorManag er.decorate(LightweightDecoratorManager.java:258)
org.eclipse.ui.internal.decorators.LightweightDecoratorManag er.getDecorations(LightweightDecoratorManager.java:241)
org.eclipse.ui.internal.decorators.DecorationScheduler$1.run (DecorationScheduler.java:285)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:66)
The last thing I did before this happened was install an eval copy of the
SWT Designed from Instantiations. It worked afterwards, but the next time
a brought Eclipse up it exhibited this problem. I have removed the plugin
files for the SWT Designer, but that didn't fix the problem. Nor does
reinstalled Eclipse.
Any idea what has happened and what I need to do to fix it?
Rob Tanner
Linfield College
rtanner@linfield.edu
FUDForum. Page generated in 0.04368 seconds
