Home » Eclipse Projects » Eclipse Platform » subversion PDEBuild?
subversion PDEBuild? [message #270912] Thu, 09 September 2004 15:29 Go to next message
Has anyone managed to get PDEBuild to work with subversion?
Re: subversion PDEBuild? [message #270984 is a reply to message #270912] Fri, 10 September 2004 06:49 Go to previous message
Originally posted by: pascal.ibm.canada
If you want to use the "automated fetching" you need to change pde build
code.
If you are just willing to compile the code with pde build, then the
only requirement is for you to respectively lay down plugins and
features in their folders.
In a 3.1 timeframe we are looking in making this end more flexible.
There is a bug report talking about this problem.
PaScaL
Previous Topic:Adding marker issue to the "Problems" view
Next Topic:set editor as default edtior in preferences-workbench-file associations
Current Time: Fri Nov 14 09:40:39 EST 2025
Powered by FUDForum. Page generated in 0.02846 seconds
