Home » Eclipse Projects » Remote Application Platform (RAP) » How does RAP team automate test RAP ?
How does RAP team automate test RAP ? [message #26801] Wed, 23 May 2007 05:49 Go to next message
I was wondering how do you guys at RAP team test this RAP framework
especially the UI part ? Do you also use unit testing framework like
JUnit/TestNG to automate test RAP ? or UI tester for web apps like
Selenium ?
Any hints would be greatly appreciated.
Best Regards,
Setya
Re: How does RAP team automate test RAP ? [message #26920 is a reply to message #26801] Wed, 23 May 2007 09:12 Go to previous messageGo to next message
Originally posted by: benedikt.arnold.beyondsoft.de
Hi!
Have a look at the "org.eclipse.rap.rwt.test" projekt wich you will find in
the cvs repository. There you will find a lot of unit tests for ui elements.
Greetings,
Benedikt
"Setya" <jsetya@gmail.com> schrieb im Newsbeitrag
news:c87c17a18b88d719795ac12c0380c4e3$1@www.eclipse.org...
> Selenium ?
> Best Regards,
> Setya
Re: How does RAP team automate test RAP ? [message #27234 is a reply to message #26920] Thu, 24 May 2007 05:29 Go to previous message
Thank you for your response,
I've downloaded org.eclipse.rap.rwt.test from CVS, but all I can see is
tests against RWT, not RAP.
For instance, in my WorkbenchWindowAdvisor I override preWindowOpen method:
public void preWindowOpen()
IWorkbenchWindowConfigurer configurer = getWindowConfigurer();
configurer.setTitle("RAP");
I need to assert that the title in my RAP application is truly "RAP".
How to do test like this ?
Best Regards,
Setya
Previous Topic:Will ActionSet ext. point be available in RAP ?
Next Topic:Closing Dialog with ESC key
Current Time: Thu Nov 06 03:01:47 EST 2025
Powered by FUDForum. Page generated in 0.06080 seconds
