Home » Newcomers » Newcomers » Eclipse Error
Eclipse Error [message #270211] Fri, 10 April 2009 04:52 Go to next message
I had been using Eclipse SDK 3.0.1 on win98 after installing j2sdk
1.4.2_19 for nearly 2 months and I had practised a number of codes.
Suddenly, one day it started giving the following error
" Could not find the main file. The system will close"
2. Thinking, perhaps, that the Eclipse file has gone corrupt, I deleted it
and copy/pasted again from the CD. Thereafter when I tried to open it, it
gives out the following error and does not open.
"An error has occurred. See the log file i:\02( or l:\02 or j:\ 02 I
cannot make out")
3. A very interesting phenomenon is that WHEN I OPEN IT FROM CD ROM, IT
WORKS FINE AND I CAN RUN ANY CODE.
4. A befuddling situation. Can someone help ??
5. In the meantime, I have started using JCreator.
Re: Eclipse Error [message #270213 is a reply to message #270211] Fri, 10 April 2009 05:11 Go to previous messageGo to next message
> it and copy/pasted again from the CD. Thereafter when I tried to open
> it, it gives out the following error and does not open.
> I cannot make out")
1. Any particular reason you wish to use Eclipse 3.0.1 instead of latest 3.4.2?
2. Looks like a path issue.
3. If it works from CD, it SHOULD work from HDD too. Make sure the JDK you installed is marked system jvm. If I recall correctly its JDK_ROOT environment variable. Need to google to be sure.
4. Indead.
5. Wish you luck!!
hth,
Ankur..
Re: Eclipse Error [message #270214 is a reply to message #270213] Fri, 10 April 2009 05:52 Go to previous messageGo to next message
I prefer working on win98(even though I am on dual booting system
alongwith winXP) as long as possible. I don,t think 3.4.1 works on win98.
3. "Make sure the JDK you installed is marked system jvm." How do we do
this ??
Re: Eclipse Error [message #270218 is a reply to message #270211] Fri, 10 April 2009 13:40 Go to previous message
"mgm2010 " <benjamin1xy@yahoo.co.in> wrote in message
news:5bc333800c0cbb9d1d26e9a98e12e213$1@www.eclipse.org...
>I had been using Eclipse SDK 3.0.1 on win98 after installing j2sdk 1.4.2_19
>for nearly 2 months and I had practised a number of codes. Suddenly, one
> cannot make out")
Sounds like perhaps your hard disk is dying, or you have a virus.
Previous Topic:Eclipse Error
Next Topic:Eclipse Download Older Version for Mac OS X
Current Time: Wed Aug 27 14:49:02 EDT 2025
Powered by FUDForum. Page generated in 0.09937 seconds
