Home » Eclipse Projects » Eclipse Platform » Does Eclipse use any code coverage tool for the automated test suite.
Does Eclipse use any code coverage tool for the automated test suite. [message #270007] Fri, 03 September 2004 08:55 Go to next message
Does the Eclipse project team use any code coverage tool for the
automated test suite? If so, can you please let me know the code coverage
tool? If not , what is the best tool which can be used against the
Thanks & Regards
Balasubramaniyan K
Re: Does Eclipse use any code coverage tool for the automated test suite. [message #270171 is a reply to message #270007] Sat, 04 September 2004 08:18 Go to previous messageGo to next message
Originally posted by: pascal.ibm.canada
We do not use code coverage tool.
I heard about Quilt (http://quilt.sourceforge.net/) but I'm not sure if
their instrumentation system (which happens at runtime) would work with
eclipse.
PaScaL
Balasubramaniyan K wrote:
> Hi
> Thanks & Regards
> Balasubramaniyan K
Re: Does Eclipse use any code coverage tool for the automated test suite. [message #270347 is a reply to message #270171] Mon, 06 September 2004 23:31 Go to previous message
Originally posted by: rradc.worldnet.att.net
I use hansel (http://hansel.sourceforge.net/) with Eclipse 3.0; it's plain
vanilla branch coverage - it just reports non-covered branches from your test
suite.
Bob Radcliffe
Aoccdrnig to rseerach at Cmabrigde Uinervtisy,
it deosn't mttaer in waht oredr the ltteers in a
wrod are, the olny iprmoatnt tihng is taht the
frist and lsat lteter be at the rghit pclae.
The rset can be a ttoal mses and you can slitl
raed it wotihut porbelm. Tihs is bcuseae the
hmuan mnid deos not raed ervey lteter by istlef,
but the wrod as a wlohe. Amzanig, huh?
web site: http://rradc.home.att.net
"Pascal Rapicault" <pascal@ibm.canada> wrote in message
news:chcbkk$97k$1@eclipse.org...
> eclipse.
> PaScaL
> > Hi
> > Thanks & Regards
> > Balasubramaniyan K
Previous Topic:Why Java runtime or JDK is needed now but not before?
Next Topic:Distributing part of a derivative work in object code form only, possible?
Current Time: Sat Jul 26 16:05:54 EDT 2025
Powered by FUDForum. Page generated in 0.05122 seconds
