3.4.2: code completion suddenly messed up? [message #269939] |
Fri, 03 April 2009 04:10  |
Folks;
after starting my IDE this morning, it seems all of a sudden Java
code-completion in my plugin projects doesn't work anymore. Situation:
- Starting writing a type name and using CTRL+Space just leaves me with a
window showing "No default proposals" whereas, earlier, it used to show
matching types and, subsequently, adjust my imports correctly. Manually
writing the type name and using "organize imports" works however.
- Using a declared local variable, CTRL+Space just ends up with "No default
proposals" as well when trying to see what methods are available here.
Again, manually writing this down works.
Any hints on what possibly could be wrong? The workspaces .metadata/.log
doesn't provide any information on that. The only error I see in the IDE
Error log is as follows but I am not sure it is related to it. Restarting
with -clean didn't help either.
Comments, anyone?
Thanks in advance and best regards,
Kristian
org.eclipse.swt.SWTException: Device is disposed
at org.eclipse.swt.SWT.error(SWT.java:3777)
at org.eclipse.swt.SWT.error(SWT.java:3695)
at org.eclipse.swt.SWT.error(SWT.java:3666)
at org.eclipse.swt.widgets.Display.error(Display.java:1142)
at org.eclipse.swt.widgets.Display.asyncExec(Display.java:665)
org.eclipse.ui.internal.console.ConsoleDropDownAction.consol esRemoved(ConsoleDropDownAction.java:150)
org.eclipse.ui.internal.console.ConsoleManager$ConsoleNotifi er.run(ConsoleManager.java:154)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
org.eclipse.ui.internal.console.ConsoleManager$ConsoleNotifi er.notify(ConsoleManager.java:174)
org.eclipse.ui.internal.console.ConsoleManager.fireUpdate(Co nsoleManager.java:262)
org.eclipse.ui.internal.console.ConsoleManager.removeConsole s(ConsoleManager.java:244)
at org.eclipse.team.svn.ui.console.SVNConsole.shutdown(SVNConso le.java:90)
at org.eclipse.team.svn.ui.SVNTeamUIPlugin.stop(SVNTeamUIPlugin .java:110)
org.eclipse.osgi.framework.internal.core.BundleContextImpl$3 .run(BundleContextImpl.java:1050)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s top(BundleContextImpl.java:1046)
org.eclipse.osgi.framework.internal.core.BundleHost.stopWork er(BundleHost.java:457)
org.eclipse.osgi.framework.internal.core.AbstractBundle.susp end(AbstractBundle.java:531)
org.eclipse.osgi.framework.internal.core.Framework.suspendBu ndle(Framework.java:1104)
org.eclipse.osgi.framework.internal.core.StartLevelManager.d ecFWSL(StartLevelManager.java:655)
org.eclipse.osgi.framework.internal.core.StartLevelManager.d oSetStartLevel(StartLevelManager.java:312)
org.eclipse.osgi.framework.internal.core.StartLevelManager.s hutdown(StartLevelManager.java:257)
org.eclipse.osgi.framework.internal.core.SystemBundle.suspen d(SystemBundle.java:236)
org.eclipse.osgi.framework.internal.core.Framework.shutdown( Framework.java:678)
at org.eclipse.osgi.framework.internal.core.Framework.close(Fra mework.java:576)
at org.eclipse.osgi.framework.internal.core.OSGi.close(OSGi.jav a:41)
org.eclipse.core.runtime.adaptor.EclipseStarter.shutdown(Ecl ipseStarter.java:424)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:200)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
Eclipse version:
Eclipse SDK
Version: 3.4.2
Build id: M20090211-1700
Re: 3.4.2: code completion suddenly messed up? [message #269941 is a reply to message #269939] |
Fri, 03 April 2009 05:10  |
Kristian Rink wrote:
> Folks;
Go to the Java > Editor > Content Assist > Advanced preference page and
restore it to its defaults. Note that the exception is unrelated to your
problem as it happened on shutfown (see bug
https://bugs.eclipse.org/bugs/show_bug.cgi?id=257970).
Dani
> Comments, anyone?
> Kristian
> at
> at
> at
> at
> at
> at
> at java.security.AccessController.doPrivileged(Native Method)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at java.lang.reflect.Method.invoke(Method.java:597)
> Eclipse version:
> Eclipse SDK
> Version: 3.4.2
FUDForum. Page generated in 1.71830 seconds
