| how to have copy-paste with middle click [message #2260] |
Fri, 20 April 2007 04:52  |
Originally posted by: ludovic.gasc.gmcl2.com
I'm on Linux, I used often the copy-paste with middle click, but it doesn't
work properly with eclipse.
Do you have an idea for this ?
Thanks for your response.
| Re: how to have copy-paste with middle click [message #2350 is a reply to message #2320] |
Mon, 23 April 2007 12:30  |
You should log a bug report with SWT (
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=Platform ). I believe
that this works in general, but perhaps you're in an unusual environment
that's showing a bug.
Grant
"Ludovic Gasc" <ludovic.gasc@gmcl2.com> wrote in message
news:f0cfde$foq$1@build.eclipse.org...
> Benjamin Muskalla wrote:
> > Hi Ludovic,
> > I've never seen any problems with this. Works for me as expected.
> > Maybe you could explain what exactly "does not work".
> The copy-paste with middle click works only When I select two times the
same
> text. If I select one time only, I have the old copied text.
> I'm on KDE 3.5.6.
> > Greets,
> > Benny
> > Ludovic Gasc wrote:
> >> Hi,
> >> doesn't work properly with eclipse.
| Re: how to have copy-paste with middle click [message #564936 is a reply to message #2260] |
Fri, 20 April 2007 08:08  |
Hi Ludovic,
Greets,
Benny
Ludovic Gasc wrote:
| Re: how to have copy-paste with middle click [message #564965 is a reply to message #2290] |
Sat, 21 April 2007 03:44  |
> Hi Ludovic,
The copy-paste with middle click works only When I select two times the same
I'm on KDE 3.5.6.
> Greets,
> Benny
> Ludovic Gasc wrote:
| Re: how to have copy-paste with middle click [message #564982 is a reply to message #2320] |
Grant
> > Hi Ludovic,
same
> I'm on KDE 3.5.6.
> > Greets,
> > Benny
> > Ludovic Gasc wrote:
> >> Hi,
FUDForum. Page generated in 0.05140 seconds
