Home » Newcomers » Newcomers » Why Eclipse gives warnings in JSP fragments?
Why Eclipse gives warnings in JSP fragments? [message #269875] Wed, 01 April 2009 09:58 Go to next message
Originally posted by: agz.pisem.net
Hello.
I've imported a web-application project into Eclipse. Now I have a lot of warnings in
/WEB-INF/jspf/*.jspf. The warnings are about HTML inconsistency, but the files are just fragments,
like page headers and footers.
For example, header.jspf contains starting <html>..<body><div> tags and footer.jspf contains
matching closing pairs.
How to get rid of those warnings or what I'm doing wrong?
Andrew.
Re: Why Eclipse gives warnings in JSP fragments? [message #269883 is a reply to message #269875] Wed, 01 April 2009 13:51 Go to previous messageGo to next message
On 4/1/2009 9:58 AM, exquisitus wrote:
> Hello.
> of warnings in /WEB-INF/jspf/*.jspf. The warnings are about HTML
> inconsistency, but the files are just fragments, like page headers and
> footers.
> footer.jspf contains matching closing pairs.
If you don't get a response here, you might want to try asking the
question in the eclipse.webtools newsgroup.
Hope this helps,
Eric
Re: Why Eclipse gives warnings in JSP fragments? [message #269930 is a reply to message #269875] Thu, 02 April 2009 22:05 Go to previous messageGo to next message
> footers.
There should be an option on the JSP Files "Validation" preference
page to disable validating those files, starting with Ganymede (WTP
3.0). In earlier releases, I think it's just on the main JSP Files
preference page.
Nitin Dahyabhai
Eclipse WTP Source Editing
IBM Rational
Re: Why Eclipse gives warnings in JSP fragments? [message #269948 is a reply to message #269930] Fri, 03 April 2009 08:32 Go to previous messageGo to next message
Thank you very much. I hope regardless that option the Eclipse consider a JSP and all its fragments
as a single JSP source and does not miss errors in JSP fragments when validates the original JSP.
Andrew.
>> footers.
>> and footer.jspf contains matching closing pairs.
> There should be an option on the JSP Files "Validation" preference page
> to disable validating those files, starting with Ganymede (WTP 3.0). In
> earlier releases, I think it's just on the main JSP Files preference page.
Re: Why Eclipse gives warnings in JSP fragments? [message #269965 is a reply to message #269948] Fri, 03 April 2009 21:47 Go to previous message
> a JSP and all its fragments as a single JSP source and does not miss
The JSP validator is at least smart enough to pull in referenced
fragments when doing its Java validation of the JSP--and to tell you
when it can't find a fragment.
Nitin Dahyabhai
IBM Rational
Previous Topic:How to locate an xml file from Eclipse preferences
Next Topic:Eclipse start up giving errors
Current Time: Sun Oct 26 06:58:24 EDT 2025
Powered by FUDForum. Page generated in 0.11391 seconds
