Home » Eclipse Projects » Dynamic Languages Toolkit (DLTK) » IScriptBuilder
IScriptBuilder [message #26721] |
Wed, 25 June 2008 13:58  |
Originally posted by: tatianamur.gmail.com
Hi everyone,
I have a simple class implementing IScriptBuilder and noticed, that it
is being called 4 times on full project rebuild by DLTK's ScriptBuilder.
First time - with correct list of ISourceModule's and
IScriptBuilder.FULL_BUILD status and 3 more times with
IScriptBuilder.FULL_BUILD (1 time) and IScriptBuilder.INCREMENTAL_BUILD
(2 times) with empty list of ISourceModule's.
Is it a bug and if it is not, how IScriptBuilder implementing class
could understand a state it is in - how to differentiate a case, when
all modules were removed from the project from a case when it is just
being called for some reasons from ScriptBuilder with empty list of files?
Tatiana
Re: IScriptBuilder [message #28113 is a reply to message #27915] |
Fri, 11 July 2008 13:48   |
What I'd like to know is when/how the project source modules are parsed and
turned into model elements. I know this happens via the reconciler, which
happens at least when you make changes to the working copy in the editor,
and via the indexer. I thought that perhaps this did or should happen via a
builder - but upon closer inspection this doesn't appear to be the case.
Thus, I am in the process of trying to write code for the builder to:
a) parse each source module element (and turn it into corresponding models)
b) run our custom semantic checker
Per your recommendation, I already moved the semantic checker into
ISourceElementParser.parseSourceModule (rather than ISourceParser.parse).
So, I thought I should call my existing method that already does what I
want.
When I looked at who called parseSourceModule, I found that it is called by
SourceParserUtil.parseSourceModule. That method is called by
AbstractSourceModule.buildStructure.
I have a few questions (besides the ones implied above):
0) Should my builder be doing parsing and model building - or is that
done automatically from something else?
1) How do I determine the nature ID for a project/source-module/parser?
I can get the list of nature ids for a project from its project
description.
Some methods I want to call take a nature id, and others take
IModelElement.
For example, I was calling DLTKLanguageManager.getProblemFactory().
2) Do I need to set the parser's (ISourceElementParser) problem
requestor?
If so, how do I create it?
Chuck
"Andrei Sobolev" <haiodo@xored.com> wrote in message
news:g4va9r$qfk$1@build.eclipse.org...
> Hi Tatiana,
> Script builder worked using following scenario:
> 1) Find all resources
> 2) Find all external source modules
> 3) Check which resources are source modules
> 4) Build resources -> call IScriptBuilder.buildResources()
> 5) Build source modules with resources -> call
> IScriptBuilder.buildModelElements()
> 6) Build external and builtin source modules -> call
> Also sometimes it incorrectly called with empty list.
> Now It works with following scanario:
> 5) Build source modules -> call IScriptBuilder.buildModelElements()
> No more calls with empty lists.
> Fix are in HEAD.
> Andrei.
>> Hi everyone,
>> I have a simple class implementing IScriptBuilder and noticed, that it is
>> Is it a bug and if it is not, how IScriptBuilder implementing class could
>> understand a state it is in - how to differentiate a case, when all
>> modules were removed from the project from a case when it is just being
>> Thanks
>> Tatiana
Re: IScriptBuilder [message #28151 is a reply to message #28113] |
Fri, 11 July 2008 14:45   |
> requestor?
Apparently the issue to this question is yes I do - otherwise there is a
null pointer exception.
If I can't figure this out, then perhaps I will
a) get the ISourceParser instead and call parse (calling
SourceParserUtil.getModuleDeclaration)
b) call my semantic checker directly
Chuck
"Chuck Doucette" <cdoucette@vaultus.com> wrote in message
news:g586f8$s8l$1@build.eclipse.org...
> and turned into model elements. I know this happens via the reconciler,
> which happens at least when you make changes to the working copy in the
> editor, and via the indexer. I thought that perhaps this did or should
> happen via a builder - but upon closer inspection this doesn't appear to
> be the case. Thus, I am in the process of trying to write code for the
> builder to:
> models)
> want.
> by SourceParserUtil.parseSourceModule. That method is called by
> description.
> IModelElement.
> requestor?
> Chuck
>> Hi Tatiana,
>> Fix are in HEAD.
>> Thanks,
>> Andrei.
>>> Hi everyone,
>>> files?
>>> Thanks
>>> Tatiana
Re: IScriptBuilder [message #28190 is a reply to message #28113] |
Fri, 11 July 2008 14:59  |
I determined the answer to this question:
> description.
> IModelElement.
Apparently, I can call:
a) IDLTKLanguageToolkit toolkit =
DLTKLanguageManager.getLanguageToolkit(module);
b) String natureId = toolkit.getNatureId()
Chuck
> builder to:
> models)
> want.
> description.
> IModelElement.
> requestor?
> Chuck
>> Hi Tatiana,
>> Fix are in HEAD.
>> Thanks,
>> Andrei.
>>> Hi everyone,
>>> files?
>>> Thanks
>>> Tatiana
Current Time: Fri Oct 17 17:22:21 EDT 2025
Powered by FUDForum. Page generated in 0.06866 seconds
