| Error after ganymede update [message #269404] |
Mon, 16 March 2009 11:33  |
Originally posted by: ciccio.ciccio.it
I've downloaded ganymede for windows, Java EE Developers version,
installed and it worked fine.
I've updated it, and it does not working anymore: it complains for an
error and says "An error has occourred. See the log file".
In the log file I have the following errors:
!SESSION 2009-03-16 16:28:35.008
eclipse.buildId=M20090211-1700
java.version=1.6.0_03
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=it_IT
Framework arguments: 256M
Command-line arguments: -os win32 -ws win32 -arch x86 256M
!ENTRY org.eclipse.update.configurator 4 0 2009-03-16 16:28:46.684
!MESSAGE Unable to access file
" plugins/org.eclipse.datatools.sqltools.sqlbuilder_1.0.0.v200 901280650.jar!META-INF/MANIFEST.MF ".
!ENTRY org.eclipse.update.configurator 4 0 2009-03-16 16:28:46.975
" plugins/org.eclipse.equinox.p2.metadata.generator_1.0.4.v200 81217.jar!META-INF/MANIFEST.MF ".
!ENTRY org.eclipse.update.configurator 4 0 2009-03-16 16:28:47.095
" plugins/org.eclipse.jdt.core_3.4.4.v_894_R34x.jar!META-INF/M ANIFEST.MF ".
!ENTRY org.eclipse.update.configurator 4 0 2009-03-16 16:28:47.125
" plugins/org.eclipse.jdt.doc.user_3.4.2.r342_v20081119-0800.j ar!META-INF/MANIFEST.MF ".
!ENTRY org.eclipse.update.configurator 4 0 2009-03-16 16:28:47.205
" plugins/org.eclipse.jdt.ui_3.4.2.r342_v20090107-0800.jar!MET A-INF/MANIFEST.MF ".
!ENTRY org.eclipse.update.configurator 4 0 2009-03-16 16:28:47.275
" plugins/org.eclipse.jface_3.4.2.M20090107-0800.jar!META-INF/ MANIFEST.MF ".
!ENTRY org.eclipse.update.configurator 4 0 2009-03-16 16:28:47.385
" plugins/org.eclipse.jst.j2ee.core_1.1.203.v200901221030.jar! META-INF/MANIFEST.MF ".
!ENTRY org.eclipse.update.configurator 4 0 2009-03-16 16:28:47.886
" plugins/org.eclipse.pde.doc.user_3.3.1.r342_v20081024.jar!ME TA-INF/MANIFEST.MF ".
!ENTRY org.eclipse.update.configurator 4 0 2009-03-16 16:28:47.966
" plugins/org.eclipse.platform.doc.user_3.4.2.r342_v20081031-0 800.jar!META-INF/MANIFEST.MF ".
!ENTRY org.eclipse.update.configurator 4 0 2009-03-16 16:28:48.397
" plugins/org.eclipse.wst.jsdt.core_1.0.104.v200901281939.jar! META-INF/MANIFEST.MF ".
!ENTRY org.eclipse.update.configurator 4 0 2009-03-16 16:28:48.437
" plugins/org.eclipse.wst.jsdt.doc_1.0.103.v200810081720.jar!M ETA-INF/MANIFEST.MF ".
!ENTRY org.eclipse.update.configurator 4 0 2009-03-16 16:28:48.447
" plugins/org.eclipse.wst.jsdt.support.ie_1.0.103.v20081002184 0.jar!META-INF/MANIFEST.MF ".
!ENTRY org.eclipse.update.configurator 4 0 2009-03-16 16:28:48.457
" plugins/org.eclipse.wst.jsdt.ui_1.0.104.v200901290004.jar!ME TA-INF/MANIFEST.MF ".
!ENTRY org.eclipse.update.configurator 4 0 2009-03-16 16:28:48.607
" plugins/org.eclipse.wst.ws.explorer_1.0.309.v200901271844.ja r!META-INF/MANIFEST.MF ".
!ENTRY org.eclipse.update.configurator 4 0 2009-03-16 16:28:48.627
" plugins/org.eclipse.wst.wsdl.ui.doc.user_1.0.550.v2009012320 40.jar!META-INF/MANIFEST.MF ".
!ENTRY org.eclipse.equinox.app 0 0 2009-03-16 16:28:48.887
!MESSAGE Product org.eclipse.platform.ide could not be found.
!ENTRY org.eclipse.equinox.p2.reconciler.dropins 4 0 2009-03-16 16:28:48.947
!MESSAGE
!STACK 0
org.osgi.framework.BundleException: The bundle could not be resolved.
Reason: Missing Constraint: Import-Package:
org.eclipse.equinox.internal.p2.extensionlocation; version="0.0.0"
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:305)
org.eclipse.osgi.framework.internal.core.AbstractBundle.resu me(AbstractBundle.java:355)
org.eclipse.osgi.framework.internal.core.Framework.resumeBun dle(Framework.java:1074)
org.eclipse.osgi.framework.internal.core.StartLevelManager.r esumeBundles(StartLevelManager.java:616)
org.eclipse.osgi.framework.internal.core.StartLevelManager.i ncFWSL(StartLevelManager.java:508)
org.eclipse.osgi.framework.internal.core.StartLevelManager.d oSetStartLevel(StartLevelManager.java:299)
org.eclipse.osgi.framework.internal.core.StartLevelManager.d ispatchEvent(StartLevelManager.java:489)
org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEve nt(EventManager.java:211)
org.eclipse.osgi.framework.eventmgr.EventManager$EventThread .run(EventManager.java:321)
These are only the beginning.
What's wrong?
How can I fix it?
Thanks in advance
| Re: Error after ganymede update [message #269522 is a reply to message #269501] |
Wed, 18 March 2009 11:23  |
"sandman42" <ciccio@ciccio.it> wrote in message
news:gpqeqp$5vi$1@build.eclipse.org...
> Ray Hurst wrote:
>> Best to just re-install it. Trying to figure out what is corrupted will
>> take you hours.
> Sure. but reinstalling brings me back to the orginal version, without
> updates. Any other idea?
This sounds the same as the problem reported in another thread, "Can't
install a thing", on 3/17. Seems like something to do with the DTP
repository maybe. You might want to keep an eye on that thread, and
possibly also take a look at the dtp newsgroups to see if there's any info.
But I'd suggest that either you, the poster of the other thread, or both,
enter a bug report in Bugzilla - that's probably the fastest way to get
action if something is actually broken, as it seems to be.
FUDForum. Page generated in 0.13603 seconds
