Home » Newcomers » Newcomers » looking for plugin to filter lines from the Console window
looking for plugin to filter lines from the Console window [message #269372] Sat, 14 March 2009 21:12 Go to next message
I am looking for a plugin that would allow me to filter away console
output that I do not want to see.
I am using Eclipse with the BlackBerry simulator. The simulator
outputs a ton of junk to the Console. Meanwhile my code is outputting
relatively few line of output, that I need to see, in real time, as I
select and click the track wheel in the simulator. The problem is that
the output from the simulator causes my output to scroll out of view
almost immediately. While I am scrolling back to find my output, the
junk from the simulator keeps coming. It would be really nice to block
the junk from the simulator, from ever getting to the console window.
Does anyone know of such a plugin out there?
Paul
Re: looking for plugin to filter lines from the Console window [message #269423 is a reply to message #269372] Tue, 17 March 2009 03:06 Go to previous messageGo to next message
probably you may look into logback
http://logback.qos.ch/consolePlugin.html
Re: looking for plugin to filter lines from the Console window [message #269726 is a reply to message #269423] Tue, 24 March 2009 11:47 Go to previous message
Ludwig,
Thank you for the reply. Sorry for the delay in getting back you.
I've looked at the link you gave. It looks like it will do the job I need.
Thanks again,
Paul
Previous Topic:Problems with JEE Update
Next Topic:Sharing run configurations
Current Time: Wed Nov 05 16:35:02 EST 2025
Powered by FUDForum. Page generated in 0.10619 seconds
