Home » Archived » XML Schema Definition (XSD) » Default values of attributes
Default values of attributes [message #26677] Sun, 24 August 2003 04:09 Go to next message
I am trying to parse an XSD containing the following attribute definition,
and am getting an error:
<xs:attribute name="mustUnderstand" default="0">
<xs:simpleType>
<xs:restriction base="xs:boolean">
<xs:pattern value="0|1"/>
</xs:restriction>
</xs:simpleType>
</xs:attribute>
The same error also occurs with:
<xs:attribute name="mustUnderstand" type="xs:boolean" default="0" />
The error is:
XSD: The value '0' of attribute 'default' must be of type
'http://www.w3.org/2001/XMLSchema#boolean'
The schema I'm trying to parse is the official W3C Soap:
http://www.w3.org/2001/06/soap-envelope.
Any reason why this shouldn't work. I looked at
http://www.w3.org/TR/xmlschema-2/#boolean and it seems that this it's
syntax to refer to a boolean literal as 0 or 1. After changing the default
to false or true, it parsed ok.
Hayden Marchant
Re: Default values of attributes [message #26763 is a reply to message #26677] Sun, 24 August 2003 08:57 Go to previous message
Hayden,
Your right, and I didn't know that. Please open a bugzilla defect and I'll
fix it for the next driver It's a simple change to
org.eclipse.xsd.impl.type.XSDBooleanType.
> <xs:simpleType>
> </xs:restriction>
> </xs:simpleType>
> </xs:attribute>
> The error is:
> Hayden Marchant
Re: Default values of attributes [message #576238 is a reply to message #26677] Sun, 24 August 2003 08:57 Go to previous message
Hayden,
> <xs:simpleType>
> </xs:restriction>
> </xs:simpleType>
> </xs:attribute>
> The error is:
> Hayden Marchant
Previous Topic:A Search for a more gentle approach to error handling using Eclipse XSD
Next Topic:A Search for a more gentle approach to error handling using Eclipse XSD
Current Time: Thu Aug 28 14:43:43 EDT 2025
Powered by FUDForum. Page generated in 0.24975 seconds
