Home » Newcomers » Newcomers » get property'value of stereotype
get property'value of stereotype [message #269095] Fri, 06 March 2009 14:32 Go to next message
Hello, I have a problem with eclipse.
I have a uml model, which was exported by MagicDraw, which I would get the
property values of certain stereotypes.
I realizzayo the following method:
public static object loadREaccessProb (org.eclipse.uml2.uml.Actor actor,
Stereotype ste) (
String Nameste= ste.getQualifiedName();
object value = actor.getValue (getAppliedStereotype (nameste),
"Reaccessprob"));
return value;
reaccessprob where is the property I want to achieve.
the metaclasse which I applied the stereotype is Actor.
I would like now, in the main, chiamre this method.
Parameters such as current pace?
Hello thanks
Re: get property'value of stereotype [message #269099 is a reply to message #269095] Fri, 06 March 2009 15:10 Go to previous messageGo to next message
Fiorella,
It's best to ask on the UML2 newsgroup, which I've added to the "to"
list of the reply, so no need to repost.
I'm having a very hard time reading your question. You many want to
clarify it...
> the property values of certain stereotypes.
> actor, Stereotype ste) (
> "Reaccessprob"));
> return value;
> Hello thanks
Re: get property'value of stereotype [message #269103 is a reply to message #269099] Fri, 06 March 2009 16:46 Go to previous messageGo to next message
Originally posted by: Kenn.Hussey.embarcadero.com
Fiorella,
Have you tried debugging the code? Are you sure that the stereotype has been
successfully applied?
Kenn
"Ed Merks" <Ed.Merks@gmail.com> wrote in message
news:gorvuq$7t5$1@build.eclipse.org...
> Fiorella,
> It's best to ask on the UML2 newsgroup, which I've added to the "to" list
> clarify it...
>> Stereotype ste) (
>> "Reaccessprob"));
>> return value;
>> Hello thanks
Re: get property'value of stereotype [message #269114 is a reply to message #269103] Sat, 07 March 2009 02:08 Go to previous messageGo to next message
Yes the stereotype has applied, but how get the value of the property of
stereotype?
my friend told me that I must refer to metaclasse to which I applied the
stereotype and I wanted to know how to pass as this parameter metaclasse.
another thing, as the subject in hand I want to take the value?
example:
ia have this model:
<model>Data
<<REUser>><Actor>Elevator user
<<REUser>><Actor>> user
..... etc
I wanted to know the value of property REAccessProb of the stereotype
REUser on object Elevator User and I must refer to metaclass of objec to
which is applied the stereotype REUser.
I have implemented this metod:
public static Object loadREAccessProb(org.eclipse.uml2.uml.Actor
actor,Stereotype ste){
String nameSte=ste.getQualifiedName();
Object
value=actor.getValue(getAppliedStereotype(nameSte),"ReAccessProb ");
return value;
Is that the metod right for get the value of the property REAccessprob?
Re: get property'value of stereotype [message #269135 is a reply to message #269114] Mon, 09 March 2009 09:53 Go to previous message
Fiorella,
Yes, that method looks correct. Of course, it will only work if the
stereotype is in fact applied and can successfully be resolved when the
method is executed...
Kenn
"fiorella " <fiorellaepablo@hotmail.it> wrote in message
news:e794fadb53567cc8c4bcc4e8f11e6fca$1@www.eclipse.org...
> stereotype?
> example:
> ia have this model:
> <model>Data
> ..... etc
> Object
> return value;
Previous Topic:see the model with uml stereotypes and values of their properties
Next Topic:How do I set the source folder?
Current Time: Sun Jul 27 01:41:29 EDT 2025
Powered by FUDForum. Page generated in 0.08765 seconds
