Home » Eclipse Projects » Eclipse Platform » IWorkbenchPage
IWorkbenchPage [message #268971] Fri, 27 August 2004 07:49 Go to next message
Originally posted by: pt00mfr.student.bth.se
Hi, I have a plug-in with a tree of objects, and when one node in the tree
is selected, some data in the object is shown as an editor at the
IWorkbenchPage. The problem is that it always open a new page instead of
checking if an object already is open and then only make that page as the
active.
The code used is shown below:
IWorkbenchWindow window =
PlatformUI.getWorkbench().getActiveWorkbenchWindow();
IStorage storage = new StringStorage(value);
IStorageEditorInput input = new StringInput(storage);
IWorkbenchPage page = window.getActivePage();
if(page != null) {
if(page.findEditor(input) == null || (!value.equals(""))){
try {
page.openEditor(input, "org.eclipse.ui.DefaultTextEditor");
catch (PartInitException pie) {pie.printStackTrace();}
} else {
page.activate(page.findEditor(input));
/regards Frasse
Re: IWorkbenchPage [message #268995 is a reply to message #268971] Fri, 27 August 2004 09:04 Go to previous messageGo to next message
Originally posted by: nick_edgar._no.spam.please_.ca.ibm.com
Does your editor input implementation implement equals appropriately?
Note also that the openEditor call will run if (!value.equals("")) is true.
However, openEditor should not open a second editor if it finds one with the
same input already open (the find code is redundant), but both findEditor
and openEditor require equals to work on the editor input (and should
implement hashCode() too of course).
Nick
"Frasse" <pt00mfr@student.bth.se> wrote in message
news:cgn74b$fbm$1@eclipse.org...
> active.
> if(page != null) {
> try {
> } else {
> /regards Frasse
Re: IWorkbenchPage [message #269183 is a reply to message #268995] Mon, 30 August 2004 05:24 Go to previous message
Thanks for the help it works fine now. I implemented hashCode() function.
/Frasse
> Nick
> > active.
> > if(page != null) {
> > try {
> > } else {
> > /regards Frasse
Previous Topic:Eclipse 3.0 / Tomcat remote debugging
Next Topic:Cut&copy does not work.
Current Time: Sat Nov 22 19:49:08 EST 2025
Powered by FUDForum. Page generated in 0.03254 seconds
