| pathname case changed [message #268526] |
Fri, 13 February 2009 02:31 |
Working on a C program using Ubuntu 8.10 and Eclipse 3.2.2
Project directory is /home/ccp/Desktop/BERTRAND/src
Project compiles and links without problems. Try to debug and it complains:
"File /Bertrand/src/main.c does not exist."
Did this same thing earlier this evening and it worked fine. However,
after I had closed Eclipse and then restarted it, my project was gone, and
I had to recreate it. I am not doing anything fancy here. This is an old C
language program. I was able to compile it using MSVC and using the Gnu
tools from the terminal window.
FUDForum. Page generated in 0.07679 seconds
