Home » Eclipse Projects » Eclipse Platform » Macintosh?
Macintosh? [message #268105] Fri, 20 August 2004 18:30 Go to next message
Originally posted by: me.BarryBurd.com
Is there a Web site that lists the things you do differently when you use
Eclipse on a Mac (as opposed to a Windows computer)? Any help is
appreciated. I don't even know what the equivalent of right-click is on a
Mac.
Thanks.
Re: Macintosh? [message #268196 is a reply to message #268105] Mon, 23 August 2004 08:47 Go to previous messageGo to next message
Originally posted by: Andre_Weinand.oti.com
On 21.8.2004 0:30 Uhr, in article cg5ttg$hou$1@eclipse.org, "Barry Burd"
> Mac.
> Thanks.
I'm not aware of such a list.
And since most of the differences between Eclipse on Mac and Eclipse on
Windows are not Eclipse specific, they are addressed on any site that
explains how the Mac UI maps to the Windows UI.
E.g. A Windows right-click is a Control-left click on Mac (or just a
right-click if you have a mouse with > 1 button).
--andre
Re: Macintosh? [message #268253 is a reply to message #268196] Mon, 23 August 2004 12:11 Go to previous messageGo to next message
The most important difference I found is to use the 'java_swt' VM
instead of 'java'. And AFAIK Andre is the guy to explain why :)
jfyi,
Marcus
Re: Macintosh? [message #268288 is a reply to message #268253] Mon, 23 August 2004 14:40 Go to previous messageGo to next message
On 23.8.2004 18:11 Uhr, in article cgd4lp$oqo$2@eclipse.org, "Marcus Olk"
Correct, but this is only important if you want to build SWT applications
(and java_swt will go away sooner than later).
You can find infos about this in the readme_eclipse.html (int the readme
directory of your Eclipse install).
--andre
Re: Macintosh? [message #268538 is a reply to message #268105] Tue, 24 August 2004 23:57 Go to previous messageGo to next message
> Mac.
> Thanks.
Try control-click
Re: Macintosh? [message #269149 is a reply to message #268538] Sun, 29 August 2004 16:21 Go to previous messageGo to next message
I don't have a Mac, so I'm looking for a list of such differences. Is there
such a list? Thanks.
> Try control-click
Re: Macintosh? [message #269163 is a reply to message #269149] Mon, 30 August 2004 00:19 Go to previous message
Look here:
http://developer.apple.com/documentation/UserExperience/Conc eptual/OSXHIGuidelines/XHIGUserInput/chapter_2_section_3.htm l
I'm sure there is more info. Go to apple.macosx.developer.documentation
to find just about everything.
>>Try control-click
Previous Topic:Outline for whole workspace
Next Topic:Getting modify Event from text widget out to editor
Current Time: Mon Jul 21 22:10:18 EDT 2025
Powered by FUDForum. Page generated in 0.96918 seconds
