Home » Eclipse Projects » Eclipse Platform » can't add GEF plugin to required plugins
can't add GEF plugin to required plugins [message #268067] Fri, 20 August 2004 13:29 Go to next message
I'd like to use the GEF framework/plugin or the draw2d plugin in my custom
plugin.
Unfortunatly, neither the org.elipse.gef nor the org.eclipse.draw2d plugin
are available in the
Dependencies - add... listbox of the plugin.xml manifest editor.
I installed the GEF SDK and runtime. I see the corresponding subdirectories
in the features and plugin directories.
I see the feature and plugin details in the Eclipse About box (alas without
Provider Name and without Plugin Name, just the Version 3.0.0 and the id's).
What's missing?
Bernd
Re: can't add GEF plugin to required plugins [message #268076 is a reply to message #268067] Fri, 20 August 2004 13:53 Go to previous messageGo to next message
Originally posted by: richkulp.NO.SPAM.us.ibm.com
Is GEF in your target Eclipse, and not the Eclipse that is running your
development id. It looks in the target eclipse to find plugins during
development. See Windows->Preferences->Plugin Development->Target Platform.
Thanks, Rich Kulp
Re: can't add GEF plugin to required plugins [message #268084 is a reply to message #268076] Fri, 20 August 2004 14:27 Go to previous messageGo to next message
Hmm?
My eclipse installation is under
d:\eclipse-3.0
This is the location where I added the GEF plugins (and some other "custom"
plugins like de.jayefem.log4, this IS visible and addable, BTW).
My target platform currently points to the same location;
Windows->Preferences->Plugin Development->Target Platform - Location:
d:\eclipse-3.0
Alas, partially you are right, in this list, the gef/draw2d plugins/feature
do not appear.
Pressing "Reload" pops up a nice progress dialog, scanning plugins, but
afterwards nothing changed.
Pressing "Not in Workspace" (whatever that button might be for...) doesn't
even cause a flicker.
So, any idea how I could persuade eclipse to add the new plugins to this
list?
CU, Bernd
"Rich Kulp" <richkulp@NO.SPAM.us.ibm.com> wrote in message
news:cg5dlj$r62$3@eclipse.org...
Platform.
> Thanks, Rich Kulp
Re: can't add GEF plugin to required plugins [message #268096 is a reply to message #268084] Fri, 20 August 2004 15:40 Go to previous messageGo to next message
Just to make sure see that the gef plugins are physically in the plugins
directory under d:\eclipse-3.0 It should find them unless there is some
pre-req error.
Thanks, Rich Kulp
Re: can't add GEF plugin to required plugins [message #268110 is a reply to message #268067] Fri, 20 August 2004 22:37 Go to previous messageGo to next message
Originally posted by: dorian.birsan.net
This looks similar to https://bugs.eclipse.org/bugs/show_bug.cgi?id=70176 ?
"Bernd Hofner" <bernd.hofner@gmx.net> wrote in message
news:cg5c9k$pnt$1@eclipse.org...
> Hello,
> plugin.
subdirectories
without
id's).
> What's missing?
> Cheers,
> Bernd
Re: can't add GEF plugin to required plugins [message #268119 is a reply to message #268110] Sat, 21 August 2004 08:12 Go to previous message
Yep! That's it!
The problems is triggered by "incomplete" manifest files (the ones in the
META-INF subdirectories) and
the way the eclipse core processes these incomplete files. Instead of
looking in the plugin.xml for
the missing data, the core kind of discards the plugin.
A patch seems to be scheduled for Eclipse 3.0.1, but as a workaround
deleting the META-INF subdirectories in the GEF and DRAW2D plugins and
features works just fine...
Bernd
Previous Topic:[ANN] RMI Plugin for Eclipse v1.6.0
Next Topic:Altering plugin classpath dynamically?
Current Time: Sat Nov 08 08:20:34 EST 2025
Powered by FUDForum. Page generated in 0.03760 seconds
