Home » Eclipse Projects » Eclipse Platform » [RCP] Form-Based EditorPart for Working With Data Stored in a Database
[RCP] Form-Based EditorPart for Working With Data Stored in a Database [message #268057] Fri, 20 August 2004 12:28 Go to next message
Originally posted by: evan_yap.mindspring.com
Hi All!
I'm seeking advice on a design approach. If you were tasked to
build the desired EditorPart, what would you do? Most Editor examples
I've seen use EditorInputs with PersistableElements that load
and save data into XML-based IMementos.
I'm thinking that if I were to stick to the
Editor-EditorInput-ElementFactory
design pattern, I would just ignore the Memento in my implementations
of the create and save Memento methods, and use my own "data-handlers".
I would probably pass some kind of a lazy-loading datahandler to my
EditorInput, and use the same datahandler to save data to the database.
What do you think? Do I have to stick to the
Design Pattern in order to leverage existing support infrastructure for
Editors
within the Eclipse Platform, or can I deviate from it (I'm thinking I pretty
much have to stick with it, but also build from it to handle non-file-based
load and save scenarios, but maybe there are alternate routes I can take?)
Does my proposal sound OK? Are there issues I need to be aware of?
Thank you in advance for any constructive feedback, pointers,
or suggested readings.
Re: [RCP] Form-Based EditorPart for Working With Data Stored in a Database [message #268875 is a reply to message #268057] Thu, 26 August 2004 12:37 Go to previous messageGo to next message
Originally posted by: nick_edgar._no.spam.please_.ca.ibm.com
Editors need an IEditorInput, which -refers- to the content. It doesn't
represent the actual content.
If you want to preserve the editor across sessions, the editor input must
implement IPersistableElement, and have a corresponding IElementFactory (and
its extension in the plugin.xml).
However, this typically doesn't persist the whole -contents- of the editor,
just enough data to recreate the input.
For example, FileEditorInput only saves the workspace file path.
If you're getting content from a database, then you'll want the editor input
to contain enough info to point at the appropriate object or entry in the
database, and persist that pointer, but not the data itself.
Nick
"Evan Chua-Yap" <evan_yap@mindspring.com> wrote in message
news:cg58lm$kgh$1@eclipse.org...
> Hi All!
> Editors
pretty
non-file-based
Re: [RCP] Form-Based EditorPart for Working With Data Stored in a Database [message #268948 is a reply to message #268057] Fri, 27 August 2004 03:16 Go to previous message
This might help:
http://jroller.com/page/Zhou/20040215#eclipse_editors_not_ti ed_to
Marcus
Previous Topic:branding setting default perspective
Next Topic:Feature Request: Improvement in Code Assist
Current Time: Sun Nov 23 02:25:12 EST 2025
Powered by FUDForum. Page generated in 0.03853 seconds
