Home » Eclipse Projects » Eclipse Platform » Move projects between workspaces
Move projects between workspaces [message #267714] Thu, 19 August 2004 06:02 Go to next message
Originally posted by: cenedese.nospam.indel.ch
After working on some projects in a workspace I changed to a new workspace.
Then I wanted to copy the projects into this new workspace, but eclipse
doesn't
pick them up, neither automatically nor by manual refresh.
The next try was to import them but eclipse tells me that the destination
folder doesn't exist. Of course, because I want to import it. Leaving the
folder empty or variants of . and ./ didn't help either. How can I work
with
the old projects in the new workspace?
Elcipse 3.0, Win2K
bye Fabi
Re: Move projects between workspaces [message #267741 is a reply to message #267714] Thu, 19 August 2004 09:27 Go to previous messageGo to next message
Originally posted by: douglas.pollock.magma.ca
> workspace. Then I wanted to copy the projects into this new workspace, but
> eclipse doesn't pick them up, neither automatically nor by manual refresh.
> with the old projects in the new workspace?
My recommendation would be to copy the folders into the workspace, restart
Eclipse, and then import the copied folders into the workspace. This works
for me.
cheers,
d.
Re: Move projects between workspaces [message #267770 is a reply to message #267714] Thu, 19 August 2004 10:30 Go to previous messageGo to next message
Originally posted by: eclipse.rizzoweb.com
Fabi wrote:
> Hi
> doesn't
Once you have copied the old project directory into your new workspace,
start the procedure in Eclipse to create a new project with the same
name. It will detect that the project already exists and configure it
appropriately.
HTH,
Eric
Re: Move projects between workspaces [message #267784 is a reply to message #267714] Thu, 19 August 2004 11:10 Go to previous messageGo to next message
Originally posted by: wegener.cboenospam.com
Fabi wrote:
> Hi
> doesn't
> with
> Elcipse 3.0, Win2K
> Thanks
> bye Fabi
There is no need to store projects in the workspace. In fact, it is
better to have the projects outside the workspace if you are going to work
on them from different workspaces. When defining the project, uncheck the
Use default location checkbox and simply point to the directory containing
the project. Eclipse will recognize the fact that it is an Eclipse
project if it finds the .project and .classpath files.
Re: Move projects between workspaces [message #267935 is a reply to message #267784] Fri, 20 August 2004 05:10 Go to previous messageGo to next message
> > doesn't
> > with
That might work (I haven't tried), but then why didn't it pick up the
copied projects in the new workspace as the .project and .classpath files
are available as well?
bye Fabi
Re: Move projects between workspaces [message #267937 is a reply to message #267770] Fri, 20 August 2004 05:14 Go to previous messageGo to next message
> appropriately.
I think that's what I finally did though the other way round. I created
a new project and then copied over all files from the older project. But
I think the import should be improved to also allow importing whole
projects into the workspace (and therefore an empty destination directory).
bye Fabi
Re: Move projects between workspaces [message #267940 is a reply to message #267741] Fri, 20 August 2004 05:16 Go to previous messageGo to next message
> for me.
IIRC, I also tried restarting which didn't work for me. But I anyway try to
restart as little as possible as it always takes quite some time :)
bye Fabi
Re: Move projects between workspaces [message #267999 is a reply to message #267935] Fri, 20 August 2004 09:56 Go to previous message
>>>doesn't
>>>with
It does not *automatically* open them because Eclipse allows you to have
directories in your workspace that are not currently open projects. You
just have to tell Eclipse that that directory is a project you want to
work with.
For example, try to delete a project - it will ask you if you want to
keep the contents of the project directory or delete them. That is so
you can later resurrect the project or move it to another workspace even
if it has been removed from your Eclipse view.
HTH,
Eric
Previous Topic:stacking views and editors
Next Topic:Find/Replace bug?
Current Time: Sat Nov 08 06:18:44 EST 2025
Powered by FUDForum. Page generated in 0.04740 seconds
