Problem in viewing "Editor" [message #267713] |
Wed, 14 January 2009 06:58 |
Hi,I am developing an "Editor" where i have added widgets in the using
SWT/JFace..When i proceeded with adding "menus" a strange thing is
happening..The window is showing only the menu with the 1 item i
added..but after resizing the window its showing the other widgets.like if
i MAXIMIZE it or RESIZE it with the MOUSE..
Please help me out of this situation..
I have used FormLayout to set the layout.
I am also sending the code along with this document..
import org.eclipse.swt.SWT;
import org.eclipse.swt.layout.FormAttachment;
import org.eclipse.swt.layout.FormData;
import org.eclipse.swt.layout.FormLayout;
import org.eclipse.swt.widgets.Composite;
import org.eclipse.swt.widgets.Control;
import org.eclipse.swt.widgets.Group;
import org.eclipse.swt.widgets.Menu;
import org.eclipse.swt.widgets.MenuItem;
import org.eclipse.swt.widgets.TabFolder;
import org.eclipse.swt.widgets.TabItem;
public class EditorTry4 extends ApplicationWindow
public EditorTry4()
super(null);
protected Control createContents(Composite parent)
getShell().setText("Graphical Custom Editor ");
getShell().setBounds(100,100,380,500);
int i;
GroupandTabfolder2 GT = new GroupandTabfolder2(parent);
return parent;
public static void main(String args[])
EditorTry4 ET4 = new EditorTry4();
ET4.setBlockOnOpen(true);
ET4.open();
Display.getCurrent().dispose();
class GroupandTabfolder2 extends Composite
public GroupandTabfolder2(Composite parent)
super(parent,SWT.NONE);
FormLayout layout = new FormLayout();
setLayout(layout);
Here i have added the menu
If you try removing only the menu the
the other widgets appear with ease..
Menu menu = new Menu(this.getShell(),SWT.BAR);
MenuItem item1 = new MenuItem(menu,SWT.CASCADE);
item1.setText("&File");
Menu fileMenu = new Menu(item1);
item1.setMenu(fileMenu);
this.getShell().setMenuBar(menu);
Group g;
g = new Group(this,SWT.SHADOW_ETCHED_IN);
FormData form = new FormData();
form.top = new FormAttachment(2);
form.bottom = new FormAttachment(99);
form.left = new FormAttachment(1);
form.right = new FormAttachment(35);
g.setLayoutData(form);
g.setText(" Tables ");
TabFolder TF = new TabFolder(this,SWT.PUSH);
form.left = new FormAttachment(g,5);
form.right = new FormAttachment(99);
form.bottom = new FormAttachment(50);
TF.setLayoutData(form);
buildTabWidgets(TF);
TabFolder TF1 = new TabFolder(this,SWT.PUSH);
form.top = new FormAttachment(TF,5);
form.bottom = new FormAttachment(80);
TF1.setLayoutData(form);
buildTabWidgets1(TF1);
Group g2 = new Group(this,SWT.NONE);
Group g3 = new Group(this,SWT.NONE);
Group g4 = new Group(this,SWT.NONE);
g2.setText("Index_field");
form.left = new FormAttachment(g,6);
form.top = new FormAttachment(TF1);
g2.setLayoutData(form);
g3.setText("Unique_field");
form.left = new FormAttachment(g2,6);
g3.setLayoutData(form);
g4.setText("Parameter");
form.left = new FormAttachment(g3,6);
g4.setLayoutData(form);
void buildTabWidgets(TabFolder tabfolder)
TabItem item1 = new TabItem(tabfolder,SWT.SHADOW_ETCHED_IN);
TabItem item2 = new TabItem(tabfolder,SWT.SHADOW_ETCHED_IN);
TabItem item3 = new TabItem(tabfolder,SWT.SHADOW_ETCHED_IN);
item1.setText("Fields");
item2.setText("Unique");
item3.setText("Indexes");
void buildTabWidgets1(TabFolder tabfolder)
item1.setText("Bit_value");
item2.setText("Default");
item3.setText("Enum_value");
void buildTabWidgets2(TabFolder tabfolder)
item1.setText("Index_field");
void buildTabWidgets3(TabFolder tabfolder)
item1.setText("Unique field");
void buildTabWidgets4(TabFolder tabfolder)
item1.setText("Param");
FUDForum. Page generated in 0.32217 seconds
