| Re: Launch Failed. Binary not found [message #267368 is a reply to message #267362] |
Mon, 29 December 2008 00:07  |
"idan zisman" <idanzisman@gmail.com> wrote in message
news:848b731670c99c021ee9b7ec806d5573$1@www.eclipse.org...
>I download eclipse for C
> I get an error when I try to run:
> What Can I do ?
You might want to take a look at
http://catb.org/~esr/faqs/smart-questions.html - it will help you ask
questions that people can answer. You also might want to look at
http://www.eclipsezone.com/eclipse/forums/t99010.rhtml (I found that with
Google just now, by searching "how to launch Eclipse"), and at
http://wiki.eclipse.org/FAQ_I_unzipped_Eclipse%2C_but_it_won %27t_start._Why%3F
and perhaps other EclipseWiki entries.
Without more details, it is very hard to say what might be wrong in your
case. For instance, I can't tell if you are asking about starting Eclipse,
or starting a program that you wrote using Eclipse; you don't say what
operating system you are running on or what version of Eclipse you
downloaded; and you don't say what troubleshooting steps you have already
tried.
Sometimes the "Binary not found" error happens when a necessary DLL cannot
be loaded. So, my first guess is that either you did not successfully unzip
the Eclipse installation. If you are running on Windows you need to use a
tool like WinZip or WinRAR, the built-in unzip tool is unreliable. This is
documented in the "Installing Eclipse" link in the "Related Links" section
of the downloads page - it is unfortunately easy to miss.
FUDForum. Page generated in 0.08746 seconds
