How to customize the date type of xsd in EMF [message #267333] |
Sat, 27 December 2008 07:06  |
Hi, all
I meet an issue, if there is date type for a xsd's element, the ecore
generated by XSDEcoreBuilder will use the default instanceClass
"javax/xml/datatype/XMLGregorianCalendar" for date type. this class is not
serializable. Now I want to use
" com.sun.org.apache.xerces.internal.jaxp.datatype.XMLGregoria nCalendarImpl "
to replace it, Do you know how to complish it?
Is it possible that change the options in resource.save(options) to
change the instanceClass?
BTW: I know if I add the annotation for instanceClass in xsd, it can
work fine, But I think maybe there is another way.
Can you help me with this?
Thanks a lot!
Re: How to customize the date type of xsd in EMF [message #267337 is a reply to message #267333] |
Sat, 27 December 2008 08:03  |
--------------070107080704070708090608
Tracy,
It's best to ask about EMF using the EMF newsgroup, which I've added to
the "to" list of the reply.
tracy wrote:
> Hi, all
> ecore generated by XSDEcoreBuilder will use the default instanceClass
> not serializable
Since https://bugs.eclipse.org/bugs/show_bug.cgi?id=246418, EMF provides
an implementation like this:
public final class XMLCalendar extends XMLGregorianCalendar implements
Serializable
You can use XMLTypeFactory.eINSTANCE.createDate to create instances of it.
> . Now I want to use
It's really a JRE question. Likely there is some magical JRE
incantation for replacing which version created by
DatatypeFactory.newInstance()
which EMF uses under the covers and wraps with the above internal
implementation.
No. But I'm a bit confused though, since the instance value doesn't
need to be java.io.Serializable in order to be saved in a resource...
That's the only way to use a different data type than the one EMF would
use by default.
I wonder why you need it the data value to be java.io.Serializable? It
shouldn't cause you any problems when saving a resource either way...
It seems to me a bug that the Xerces implementation isn't Serializable....
> Thanks a lot!
<html>
<head>
http-equiv="Content-Type">
</head>
Tracy,<br>
<br>
the "to" list of the reply.<br>
<br>
tracy wrote:
<blockquote
cite="mid:21a5b09fea149f646764f6c2a4e7fceb$1@www.eclipse.org"
type="cite">Hi, all
<br>
FUDForum. Page generated in 0.08313 seconds
