Home » Eclipse Projects » Eclipse Platform » java.lang.UnsatisfiedLinkError: no swt-win32-3062 in java.library.path
java.lang.UnsatisfiedLinkError: no swt-win32-3062 in java.library.path [message #267185] Mon, 16 August 2004 18:22 Go to next message
Originally posted by: Jeffrey_Mason.MSN.com
Newbie here, attempting to execute the SWT examples and I get the error:
Any help greatly appreciated!!!
BoomerangThree...
Re: java.lang.UnsatisfiedLinkError: no swt-win32-3062 in java.library.path [message #267191 is a reply to message #267185] Mon, 16 August 2004 18:43 Go to previous messageGo to next message
Originally posted by: Pmiodonski.fc-md.umd.edu
maybe this helps
ad this paramter to the VM arguments in the run configuration:
-Djava.library.path='your path to eclipse
dir'\eclipse\plugins\org.eclipse.swt.win32_3.0.0\os\win32\x8 6
Paul
"BoomerangThree" <Jeffrey_Mason@MSN.com> wrote in message
news:cfrbuj$ehc$1@eclipse.org...
> BoomerangThree...
Re: java.lang.UnsatisfiedLinkError: no swt-win32-3062 in java.library.path [message #267208 is a reply to message #267191] Mon, 16 August 2004 19:20 Go to previous messageGo to next message
Thanks Paul!
I have the following command line, still doesn't work:
"C:\Program Files\eclipse\eclipse.exe"
"-vmargs -Djava.library.path=c:\program
files\eclipse\plugins\org.eclipse.swt.win32_3.0.0\os\win32\x 86 "
"Paul Miodonski" <Pmiodonski@fc-md.umd.edu> wrote in message
news:cfrd6h$fr8$1@eclipse.org...
> maybe this helps
> Paul
>> BoomerangThree...
Re: java.lang.UnsatisfiedLinkError: no swt-win32-3062 in java.library.path [message #267214 is a reply to message #267208] Mon, 16 August 2004 19:45 Go to previous messageGo to next message
Originally posted by: olivier_thomannNOSPAM.ca.ibm.com
BoomerangThree wrote:
> Thanks Paul!
Try this:
-vmargs -Djava.library.path="c:\program
Olivier
Re: java.lang.UnsatisfiedLinkError: no swt-win32-3062 in java.library.path [message #267217 is a reply to message #267214] Mon, 16 August 2004 19:59 Go to previous messageGo to next message
Olivier,
Thanks for two (2) lessons, getting Eclipse to run with the vmargs and the
lesson the proper placement of the quotes. I'm still getting the error
below. Any other ideas. I downloaded the examples from the "Welcome" page
and they were auto-installed, if this helps.
at java.lang.ClassLoader.loadLibrary(Unknown Source)
at java.lang.Runtime.loadLibrary0(Unknown Source)
at java.lang.System.loadLibrary(Unknown Source)
at org.eclipse.swt.internal.Library.loadLibrary(Library.java:10 0)
at org.eclipse.swt.internal.win32.OS.<clinit>(OS.java:18)
at org.eclipse.swt.graphics.Device.init(Device.java:564)
at org.eclipse.swt.widgets.Display.init(Display.java:1780)
at org.eclipse.swt.graphics.Device.<init>(Device.java:100)
at org.eclipse.swt.widgets.Display.<init>(Display.java:355)
at org.eclipse.swt.widgets.Display.<init>(Display.java:351)
at org.eclipse.swt.examples.texteditor.TextEditor.main(TextEdit or.java:312)
Exception in thread "main"
"Olivier Thomann" <olivier_thomannNOSPAM@ca.ibm.com> wrote in message
news:cfrgpj$jli$1@eclipse.org...
>> Thanks Paul!
> Try this:
> Olivier
Re: java.lang.UnsatisfiedLinkError: no swt-win32-3062 in java.library.path [message #267301 is a reply to message #267217] Tue, 17 August 2004 09:18 Go to previous messageGo to next message
I've just downloaded and installed the examples. I run them through the 'SWT
Example Launcher' View without any problems.
I also tried to run the Address Book as Java Application and after adding
the parameter it works, without any error.
Without the parameter, I get the 'java.lang.UnsatisfiedLinkError: no
swt-win32-3062 in java.library.path' error.
I'm using eclipse 3.0.0 with JRE 1.4.2_05 on a w2k machine.
Paul
news:cfrhkb$klv$1@eclipse.org...
> Olivier,
page
> at
> >> Thanks Paul!
> > Try this:
> > Olivier
Re: java.lang.UnsatisfiedLinkError: no swt-win32-3062 in java.library.path [message #267307 is a reply to message #267185] Tue, 17 August 2004 09:26 Go to previous messageGo to next message
Originally posted by: vbychkovyak.i-hypergrid.com
there should be path to swt-win32-3062.dll file set in "java.library.path"
system property.
swt-win32-3062.dll is Windows native part of SWT library
> BoomerangThree...
Re: java.lang.UnsatisfiedLinkError: no swt-win32-3062 in java.library.path [message #267356 is a reply to message #267217] Tue, 17 August 2004 11:32 Go to previous message
Originally posted by: chaves.nospam.inf.ufsc.br.ok
You use quotes to avoid having a single command line argument that has
spaces to be accidently interpreted as multiple command line arguments. My
guess then would be that you should pass:
"-Djava.library.path=c:/program
files/eclipse/plugins/org.eclipse.swt.win32_3.0.0/os/win32/x 86 "
But I didn't try it...
Rafael
> Olivier,
> >> Thanks Paul!
> >> "C:Program Fileseclipseeclipse.exe"
> >> "-vmargs -Djava.library.path=c:program
> >> fileseclipsepluginsorg.eclipse.swt.win32_3.0.0oswin32x86"
> > Try this:
> > -vmargs -Djava.library.path="c:program
> > Olivier
Previous Topic:Turning on tracing for more than one plugin using -debug option to Eclipse
Next Topic:[RCP] imports not resolved
Current Time: Sun Nov 16 15:22:55 EST 2025
Powered by FUDForum. Page generated in 0.15338 seconds
