Home » Eclipse Projects » Eclipse Platform » preference page for package explorer
preference page for package explorer [message #267083] Mon, 16 August 2004 12:27 Go to next message
Hi!
I am trying to apply an extension point of type org.eclipse.ui.propertyPages to any roots displayed
in the Package explorer. How I define this?
Example:
<extension
point="org.eclipse.ui.propertyPages">
<page
objectClass="????"
class="MyPropertyPage"
name="MyName"
id="MyPropertyPage"/>
</extension>
[Have a nice day] / [10x]
Pope
<<There are only solutions...>>
Re: preference page for package explorer [message #267247 is a reply to message #267083] Tue, 17 August 2004 03:49 Go to previous messageGo to next message
Originally posted by: t1.s-neubert.net
your template is seems quite ok. You just have to fill in the following
informations:
- objectClass= The class which has to be selected to show your property
page. For example: objectClass="org.eclipse.jdt.core.IJavaProject" which
means that this property page will show up if the current selection is an
IJavaElement.
- class= Correct, your implementation of a org.eclipse.ui.PropertyPage
- name= and id= Choose whatever you like.
- adaptable="true" I recommend that if you do not want to define a
property page for every kind of resource. If you choose adaptable to be
true, eclipse tries to find am adapter of the type, that you've declared
in objectClass. For example: If you want a property page to show up if any
IProject resource is selected, you should define
objectClass="org.eclipse.core.resources.IProject" and adaptable="true". It
than does not matter if you select an IProject within the Navigator-view
or an IJavaProject within the Package Explorer, because eclipse is able to
find an adapter for the IJavaProject.
I hope that helps,
Tobias
the_mindstorm wrote:
> Hi!
> Example:
> <extension
> <page
> objectClass="????"
> name="MyName"
> </extension>
Re: preference page for package explorer [message #267361 is a reply to message #267247] Tue, 17 August 2004 12:14 Go to previous message
Tobias Neubert wrote:
> informations:
> IJavaElement.
> I hope that helps,
> Tobias
>>Hi!
>>Example:
>> <extension
>> <page
>> objectClass="????"
>> name="MyName"
>> </extension>
The line org.eclipse.jdt.core.IJavaProject is exactly what i wanted. How can I find out more such
objectClass-es?
Pope
Previous Topic:[RCP] imports not resolved
Next Topic:Navigator does not show project names and resources
Current Time: Sun Aug 31 18:27:13 EDT 2025
Powered by FUDForum. Page generated in 0.03948 seconds
