Home » Eclipse Projects » Eclipse Platform » Eclipse and Windows XP SP 2
Eclipse and Windows XP SP 2 [message #267068] Mon, 16 August 2004 10:52 Go to next message
All,
I found this link
( http://support.microsoft.com/default.aspx?kbid=884130&pr oduct=windowsxpsp2)
, which says that Eclipse might behave differently when running under SP 2.
Does anybody know more about this?
M. veurman
Re: Eclipse and Windows XP SP 2 [message #267080 is a reply to message #267068] Mon, 16 August 2004 11:45 Go to previous messageGo to next message
Originally posted by: markp.softlanding.com
Mathieu Veurman wrote:
> All,
> I found this link
> xpsp2) , which says that Eclipse might behave differently when
> running under SP 2. Does anybody know more about this?
> M. veurman
All I have noticed is that when you start the Help system you get a
Firewall warning. You appear to get this with any Windows app that
listens on a socket. You can then just press a button to tell the
Firewall to unblock the program.
Mark
Re: Eclipse and Windows XP SP 2 [message #267160 is a reply to message #267080] Mon, 16 August 2004 15:23 Go to previous messageGo to next message
It does not seem necessary to unblock the program (javaw). Help works fine
for me, even with javaw being blocked. I guess the firewall is smart enough
not to block local connections.
Konrad
"Mark Phippard" <markp@softlanding.com> wrote in message
news:cfqkr4$9mm$1@eclipse.org...
> > All,
> > I found this link
> > M. veurman
> Mark
Re: Eclipse and Windows XP SP 2 [message #267176 is a reply to message #267160] Mon, 16 August 2004 16:43 Go to previous messageGo to next message
Originally posted by: scott.anderson.genuitec.com
Konrad,
Of course, by not unblocking it you'll naturally kill the automatic update
mechanism too.
--Scott
"Konrad Kolosowski" <konradk@ca.ibm.com> wrote in message
news:cfr1f2$v16$1@eclipse.org...
fine
enough
> Konrad
> > > All,
> > > I found this link
> > > M. veurman
> > Mark
Re: Eclipse and Windows XP SP 2 [message #267220 is a reply to message #267068] Mon, 16 August 2004 20:18 Go to previous messageGo to next message
Originally posted by: Jeffrey_Mason.MSN.com
I was just wondering. I have SP2 installed, just installed Eclipse 3.0 and
the example apps will not work. I get the error. Do your sample apps run
ok?
java.lang.UnsatisfiedLinkError: no swt-win32-3062 in java.library.path
at java.lang.ClassLoader.loadLibrary(Unknown Source)
at java.lang.Runtime.loadLibrary0(Unknown Source)
at java.lang.System.loadLibrary(Unknown Source)
at org.eclipse.swt.internal.Library.loadLibrary(Library.java:10 0)
at org.eclipse.swt.internal.win32.OS.<clinit>(OS.java:18)
at org.eclipse.swt.graphics.Device.init(Device.java:564)
at org.eclipse.swt.widgets.Display.init(Display.java:1780)
at org.eclipse.swt.graphics.Device.<init>(Device.java:100)
at org.eclipse.swt.widgets.Display.<init>(Display.java:355)
at org.eclipse.swt.widgets.Display.<init>(Display.java:351)
at org.eclipse.swt.examples.texteditor.TextEditor.main(TextEdit or.java:312)
Exception in thread "main"
"Mathieu Veurman" <mveurman@seagull.nl> wrote in message
news:cfqhim$36p$1@eclipse.org...
> All,
> I found this link
> 2.
> M. veurman
Re: Eclipse and Windows XP SP 2 [message #267335 is a reply to message #267176] Tue, 17 August 2004 10:46 Go to previous messageGo to next message
It does not seem to prevent update for me. Automatic update opens outgoing
connections, and windows firewall does not seem to care about these.
Konrad
"Scott Anderson" <scott.anderson@genuitec.com> wrote in message
news:cfr64o$6m0$1@eclipse.org...
> Konrad,
> mechanism too.
> --Scott
> fine
> enough
> > Konrad
> > > > All,
> > > > I found this link
> > > > M. veurman
> > > Mark
Re: Eclipse and Windows XP SP 2 [message #267465 is a reply to message #267335] Wed, 18 August 2004 03:35 Go to previous message
> Konrad
That's because the XP firewall only prevents incoming connections. Outgoing
connections are all fine. Which also means that you can't prevent ANY app
from calling home. I wouldn't use the XP firewall but another product
(Kerio,
Zone Alarm, Norton, whatever).
bye Fabi
Previous Topic:Console counting on same line?
Next Topic:-> CodeAssist
Current Time: Fri Nov 07 17:29:33 EST 2025
Powered by FUDForum. Page generated in 0.03720 seconds
