Home » Eclipse Projects » SWTBot » pause in my swtbot's test
pause in my swtbot's test [message #26415] Thu, 05 March 2009 10:17 Go to next message
Hi list,
I read FAQ http://wiki.eclipse.org/SWTBot/FAQ.
I write the test below
public void testMenuFileNew() throws Exception {
bot.menu("File").click();
Thread.sleep(1000);
bot.menu("New").click();
Thread.sleep(1000);
The execution run good but I want to click on "File", stay one second,
after click on "New", wait another one second. But Test run so speed.
What I can do it?
Thanks in advance for your help.
Re: pause in my swtbot's test [message #26481 is a reply to message #26415] Thu, 05 March 2009 11:56 Go to previous messageGo to next message
Hi Brice
I've updated the FAQ to use the correct property names now. Please refer
to the faq [1] again.
If you need to slow down all your tests you can set the system property
"org.eclipse.swtbot.playback.delay" to a number of your choice, a value
of 10-20 should be good enough for most people, any higher and you'll
get bored staring at the screen :)
[1] -
http://wiki.eclipse.org/SWTBot/FAQ#Can_I_slow_down_the_execu tion_speed_of_SWTBot_tests.3F
-- Ketan
On 5/3/09 20:47, Brice Laurel wrote:
> Hi list,
> Thread.sleep(1000);
> Thread.sleep(1000);
> What I can do it?
Re: pause in my swtbot's test [message #26595 is a reply to message #26481] Thu, 05 March 2009 23:38 Go to previous messageGo to next message
Hi Ketan,
L write this class
public class FileTest extends TestCase {
public SWTEclipseBot bot;
public void setUp()throws Exception {
super.setUp();
bot = new SWTEclipseBot();
public void tearDown()throws Exception {
super.tearDown();
System.setProperty("org.eclipse.swtbot.search.timeout", "30000");
bot.menu("File").menu("New").click();
But When I run this, the execution is so speed. I want that, whenI click
on menu File -> New, I wait five(5) seconds before I continue with test.
What it wrong in my test to do what I want to do ?
Re: pause in my swtbot's test [message #26616 is a reply to message #26595] Fri, 06 March 2009 00:06 Go to previous messageGo to next message
I suppose you're referring to the fact that eclipse shuts down by the
time the menu is clicked, and therefore you don't notice anything and
you want to wait 5 secs before eclipse shuts down.
There's an option in the run config dialog to keep junit running after
the launch, or add a sleep after the test is completed.
-- Ketan
Re: pause in my swtbot's test [message #26659 is a reply to message #26616] Fri, 06 March 2009 04:18 Go to previous messageGo to next message
Thanks Ketan,
That is what I want to do.
I open the run configuration of my Eclipse IDE. But I can't do what I want
to do (wait 5 seconds after an action with swtbot). I search on google,
but I find nothing.
Can you help me to do this?
Re: pause in my swtbot's test [message #26700 is a reply to message #26659] Fri, 06 March 2009 04:44 Go to previous messageGo to next message
http://wiki.eclipse.org/Image:Run-as-config-create.jpg
There's a checkbox 'keep junit running...'
-- Ketan
On 6/3/09 14:48, Brice Laurel wrote:
> Thanks Ketan,
> want to do (wait 5 seconds after an action with swtbot). I search on
> google, but I find nothing.
Re: pause in my swtbot's test [message #26945 is a reply to message #26700] Sat, 07 March 2009 03:43 Go to previous message
Thanks Ketan,
I went to my run configuration :
1- I choose Test runner: Junit3
2- I check "Keep JUnit after a test run when debugging"
I use eclipse 3.4 and SWTBot 2.0.
Now, when I execute my testCase below
super.setUp();
super.tearDown();
SWTBotMenu menuFile = bot.menu("File");
menuFile.click();
System.setProperty("org.eclipse.swtbot.search.timeout", "5000");
SWTBotMenu menuFileNew = menuFile.menu("New");
menuFileNew.click();
I don't have what I want.
I want to do this:
1- "swtbot" click on menu "File", wait 5 seconds
2- "swtbot" click on submenu "New" wait 5 seconds and so one...
I want to visualize any step of my test.
Previous Topic:Help Shell Not Found on Windows
Next Topic:Improvement for captureScreenshot
Current Time: Thu Sep 04 01:13:29 EDT 2025
Powered by FUDForum. Page generated in 0.04983 seconds
