running myProc.jar in debug mode has the "source not found" [message #266194] |
Mon, 10 November 2008 17:02 |
I use eclipse 3.4.1 on FC6.
My java source layouts are as follows:
/home/twong/java/myjar/com/mycomp/cpt/
/home/twong/java/myjar/com/mycomp/cptx/
/home/twong/java/myProc/myProc
/home/twong/java/myProc/myProc.mf
My workspace is at:
/home/twong/eclipseworkspace
My build instructions on bash are:
cd /home/twong/java/myjar
javac -classpath ibmpkcs.jar -d . /*.java com/mycomp/cptx/*.java
jar -cf myjar.jar com/mycomp/crypto/*.class
jar -cf myjarx.jar com/mycomp/cptx/*.class
myjar.jar and myjarx.jar are used to build myProc.jar.
cd /home/twong/java/myProc
javac -d . myProc/*.java
jar -cfm myProc.jar myProc.mf myProc/*.class
To run my application:
java -jar /home/twong/eclipseworkspace/myProc.jar
What is the best way to set up my project?
Now I setup my eclipse project to build the
/home/twong/eclipseworkspace/myProc.jar file.
Now I build myjar.jar and myjarx.jar on bash.
How to setup eclipse to build myjar.jar and myjarx.jar?
I added the /home/twong/java/myjar/com/mycomp/cpt/ and
to the debug configuration source path of the launch configuration
properties.
However, running myProc.jar in debug mode has the "source not found" error.
How to fix it?
FUDForum. Page generated in 0.05375 seconds
