Home » Newcomers » Newcomers » How to strip off all unreferenced ComplexTypes from WSDL?
How to strip off all unreferenced ComplexTypes from WSDL? [message #265678] Mon, 20 October 2008 16:12 Go to next message
Originally posted by: markmccloud200.email.com
Assume I defined a new WSDL in Eclipse WSDL editor. During the definition process
I created (but later not use them) some ComplexTypes and SimpleTypes.
However these unused Types are still in the resulting WSDL file embedded.
Ok, I could search for and removed them manually in the source pane.
But I can imagine that there is an automatic tool which does the job for me.
How can I remove the AUTOMATICALL all unreferenced messages, Types, elements
from a WSDL?
Mark
Re: How to strip off all unreferenced ComplexTypes from WSDL? [message #265681 is a reply to message #265678] Mon, 20 October 2008 16:39 Go to previous messageGo to next message
Mark
I guess you're using the Web Tools project for this and should ask on
the WTP newsgroup, which I've added to the "to" list of the reply. I
doubt they have such a thing. Just because you don't use the type
locally doesn't mean that no one downstream would never use it...
I'm curious why you cross posted to platform and newcomer and why your
posting has a "Followup-To" link? I.e., how did you create this posting?
> from a WSDL?
> Mark
Re: How to strip off all unreferenced ComplexTypes from WSDL? [message #265687 is a reply to message #265681] Mon, 20 October 2008 23:32 Go to previous message
Originally posted by: valentinbaciu.hotmail.com
There are already bugzillas opened with similar requests:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=142641
https://bugs.eclipse.org/bugs/show_bug.cgi?id=183630
There's also this https://bugs.eclipse.org/bugs/show_bug.cgi?id=195063 to
provide the nice framework to plug-in all the clean-up actions.
Regards, Valentin
"Ed Merks" <Ed.Merks@gmail.com> wrote in message
news:gdiqao$2bg$3@build.eclipse.org...
> Mark
> I guess you're using the Web Tools project for this and should ask on the
> WTP newsgroup, which I've added to the "to" list of the reply. I doubt
> they have such a thing. Just because you don't use the type locally
>> process
>> me.
>> elements
>> from a WSDL?
>> Mark
Previous Topic:modify file outside of IDE, refresh proj, does not refresh all tabs in Multipage
Next Topic:Bullet points in dialog?
Current Time: Sun Nov 02 21:05:07 EST 2025
Powered by FUDForum. Page generated in 0.07070 seconds
