Home » Eclipse Projects » Remote Application Platform (RAP) » Tomcat encoding Issue
Tomcat encoding Issue [message #26323] Sun, 20 May 2007 11:02 Go to next message
Hi all, I've had another problem with character encoding, It's my
nightmare ;-)
In Tomcat, my application wasn't able to decode special characters
correctly, I can see them without problems in texts loaded from database
or in Strings hardcoded in .class, but all user inputs were bad decoded.
I tested it in Windows, MacOS and Linux with the same effect, all tomcat
distros had factory defaults, well I found the cause (now I'm happy
;-)), in server.xml in HTTP Connector there is an attribute
"URIEncoding" that doesn't appear in default server.xml file, if this
attribute isn't setted then Tomcat assume by default ISO-8859-1, and as
you know RAP works with UTF-8 pages, so when RAP try to get a
request.getParameter(...) the result it isn't correctly processed.
I have to do more test, but now all seems to be OK.
Possibly RAP could include info about this Issue in deployment tutorial
or wiki, I think that is something to take in account. I was getting mad
until I see it.
I hope this info can help other in future.
Regards.
Roberto.
Re: Tomcat encoding Issue [message #26400 is a reply to message #26323] Sun, 20 May 2007 12:11 Go to previous messageGo to next message
Link to Tomcat reference:
http://tomcat.apache.org/tomcat-5.5-doc/config/http.html
Search "URLEncoding" in page and You can see what I was speaking about.
Regards.
> nightmare ;-)
> until I see it.
> Regards.
> Roberto.
Re: Tomcat encoding Issue [message #26436 is a reply to message #26400] Mon, 21 May 2007 04:22 Go to previous message
Originally posted by: fappel.innoopract.com
thank you for this useful information. Actually the character encoding of
the request is explicitly set to 'UTF-8', that's the first thing the servlet
in the core of RAP does with every request. So I'm surprised about the
problems you encountered. Seems somehow as if the encoding settings only
work for data that was submitted with HTTP 'post'. We will have a look at
it, to see whether there is a solution without the need for configuration at
deployment time (https://bugs.eclipse.org/bugs/show_bug.cgi?id=188045).
Ciao
Frank
"Roberto S
Previous Topic:Starting RAP-Demo
Next Topic:Startup code
Current Time: Fri Jul 18 03:26:32 EDT 2025
Powered by FUDForum. Page generated in 0.40214 seconds
