Home » Newcomers » Newcomers » URGENT: Eclipse won't start
URGENT: Eclipse won't start [message #265270] Mon, 06 October 2008 14:02 Go to next message
PLEASE HELP! I'M UNDER A VERY STRICT DEADLINE
Been using Eclipse for 6 years with very few glitches.
Suddenly, when I start Eclipse, it won't and tells me to look in the log
file.
See below for the message I find in the log.
It seems lot of people experience this problem:
http://tapestryjava.blogspot.com/2004/10/worst-eclipse-crash -ever.html
And the solution that seems to work for most people is to remove this file:
\.metadata\.plugins\org.eclipse.core.resources\.snap
and
\.metadata\.plugins\org.eclipse.core.resources\.root\.marker s.snap
But I have neither of them!
I also tried the Workspace Rebuilder listed on this page:
http://www.eclipse.org/eclipse/platform-core/downloads.html
But when I run the command line:
eclipse -application org.eclipse.core.tools.restorer.application
I see the Eclipse splash screen for a few seconds, then it goes away. If I
restart Eclipse after that, still crashes. I also tried the -data option:
eclipse -application org.eclipse.core.tools.restorer.application -data
myworkspace
giving it both the name of the workspace ("eclipse_workspace" in my case)
and the full path ("D:\Documents and Settings\Desiletsa\My
Documents\eclipse_workspace") and neither of them did anything.
What can you suggest.
Thx
Alain Désilets
--- Log file message
!ENTRY org.eclipse.osgi 4 0 2008-10-06 13:46:02.205
!MESSAGE Application error
!STACK 1
java.lang.NoClassDefFoundError: org/eclipse/core/resources/IContainer
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:107)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:169)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 508)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:447)
at org.eclipse.equinox.launcher.Main.run(Main.java:1173)
Caused by:
org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter $TerminatingClassNotFoundException:
An error occurred while automatically activating bundle
org.eclipse.core.resources (39).
org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .postFindLocalClass(EclipseLazyStarter.java:125)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:417)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin dLocalClass(DefaultClassLoader.java:189)
org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:340)
org.eclipse.osgi.framework.internal.core.SingleSourcePackage .loadClass(SingleSourcePackage.java:37)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl assInternal(BundleLoader.java:405)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:369)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:357)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:83)
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
... 13 more
Caused by: org.osgi.framework.BundleException: Exception in
org.eclipse.core.resources.ResourcesPlugin.start() of bundle
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:1018)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:974)
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:346)
org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:260)
org.eclipse.osgi.framework.util.SecureAction.start(SecureAct ion.java:400)
org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .postFindLocalClass(EclipseLazyStarter.java:111)
... 23 more
Caused by: org.eclipse.core.internal.resources.ResourceException: Problems
reading workspace tree.
org.eclipse.core.internal.resources.WorkspaceTreeReader_1.re adTree(WorkspaceTreeReader_1.java:171)
org.eclipse.core.internal.resources.SaveManager.restoreTree( SaveManager.java:916)
org.eclipse.core.internal.resources.SaveManager.restore(Save Manager.java:647)
org.eclipse.core.internal.resources.SaveManager.startup(Save Manager.java:1319)
org.eclipse.core.internal.resources.Workspace.startup(Worksp ace.java:1949)
at org.eclipse.core.internal.resources.Workspace.open(Workspace .java:1713)
org.eclipse.core.resources.ResourcesPlugin.start(ResourcesPl ugin.java:363)
org.eclipse.osgi.framework.internal.core.BundleContextImpl$2 .run(BundleContextImpl.java:999)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:993)
... 28 more
Re: URGENT: Eclipse won't start [message #265275 is a reply to message #265270] Mon, 06 October 2008 17:09 Go to previous messageGo to next message
"Alain "D
Re: Eclipse won't start [message #632552 is a reply to message #265270] Wed, 13 October 2010 08:08 Go to previous message
Hi Alain,
Even I have been struggling with this problem. Did you get teh solution to it? I too don't have the .snap file. I am presently using Eclipse 3.2.1 to work on compatibility issue of a plugin.
My log file contents are as follows-
!SESSION 2010-10-11 15:37:06.148 -----------------------------------------------
eclipse.buildId=M20060921-0945
java.version=1.6.0_21
Command-line arguments: -os win32 -ws win32 -arch x86 -clean
!ENTRY org.eclipse.osgi 4 0 2010-10-11 15:37:11.163
!MESSAGE An error occurred while automatically activating bundle org.eclipse.core.resources (45).
!STACK 0
org.osgi.framework.BundleException: Exception in org.eclipse.core.internal.compatibility.PluginActivator.star t() of bundle org.eclipse.core.resources.
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:1010)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:966)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:317)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:256)
at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .preFindLocalClass(EclipseLazyStarter.java:86)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:409)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin dLocalClass(DefaultClassLoader.java:188)
at org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:334)
at org.eclipse.osgi.framework.internal.core.SingleSourcePackage .loadClass(SingleSourcePackage.java:37)
at org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:383)
at org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:347)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:83)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:96)
at org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:78)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:400)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
Caused by: java.lang.NullPointerException
at org.eclipse.core.internal.resources.MarkerTypeDefinitionCach e.loadDefinitions(MarkerTypeDefinitionCache.java:132)
at org.eclipse.core.internal.resources.MarkerTypeDefinitionCach e. <init>(MarkerTypeDefinitionCache.java:63)
at org.eclipse.core.internal.resources.MarkerManager.<init>(MarkerManager.java:32)
at org.eclipse.core.internal.resources.Workspace.startup(Worksp ace.java:1878)
at org.eclipse.core.internal.resources.Workspace.open(Workspace .java:1653)
at org.eclipse.core.resources.ResourcesPlugin.startup(Resources Plugin.java:367)
at org.eclipse.core.internal.compatibility.PluginActivator.star t(PluginActivator.java:31)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl$2 .run(BundleContextImpl.java:991)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:985)
... 26 more
Root exception:
!ENTRY org.eclipse.osgi 4 0 2010-10-11 15:37:11.178
!STACK 1
Caused by: java.lang.ClassNotFoundException: org.eclipse.core.resources.IContainer
at org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:402)
... 14 more
Only when the plugin is deployed in Eclipse, it is unable to start. If I remove the plugin from the plugins folder, everything works fine. I understand that the plugin is trying to access some jar which is not present in 3.2.1. But then how is it not showing me any build path errors?
Previous Topic:How to Export User Settings
Next Topic:unable to get chart view of gmon.out
Current Time: Sat Nov 08 15:01:24 EST 2025
Powered by FUDForum. Page generated in 0.09051 seconds
