Home » Eclipse Projects » Eclipse Platform » Can I link from a topic in the help system to an HTML file on the machine and load it in another &qu
Can I link from a topic in the help system to an HTML file on the machine and load it in another &qu [message #265244] Tue, 03 August 2004 11:39 Go to next message
Originally posted by: nospamkowalski.ibm.com
I have a topic in the Eclipse help system running in standalone mode and I
want to have a link that opens a new browser window and loads an HTML file
that's on the user's machine. The HTML file is not in an Eclipse plugin, it
is just a plain file in the filesystem.
I've done links from a topic in the help system to an external Web site
coded as:
<a href="http:www.blahblah.com" target="_blank">See this Web site</a>
and from the help system, a new "plain" browser window opens to that Web
site, which is what is desired.
Is there a similar way to code the link from an HTML topic file in a doc
plugin to open an HTML file on the file system in a new "plain" browser
window?
For example, if I have:
c://eclipse/plugins/com.ibm.blahblah.doc/
file1.html
file2.html
file3.html
and then elsewhere on the system, I have:
c://samplefiles/
aaa.html
bbb.html
is there a way to code the anchor tag so that a link in file1.html in the
help system will open a new browser window that loads file aaa.html?
Thanks!
--Lee Anne
Re: Can I link from a topic in the help system to an HTML file on the machine and load it in another [message #265279 is a reply to message #265244] Tue, 03 August 2004 15:24 Go to previous messageGo to next message
<a href="file:///c:/samplefiles/aaa.html" target="_blank">See this Web
site</a>
will do.
"Lee Anne Kowalski" <nospamkowalski@ibm.com> wrote in message
news:ceobc7$v6$1@eclipse.org...
it
> coded as:
> window?
> file1.html
> file2.html
> file3.html
> c://samplefiles/
> aaa.html
> bbb.html
> Thanks!
> --Lee Anne
Re: Can I link from a topic in the help system to an HTML file on the machine and load it in another [message #265305 is a reply to message #265279] Tue, 03 August 2004 19:48 Go to previous messageGo to next message
Hi Konrad,
That doesn't seem to be working right for me. I'm running a Version 3
standalone help system on Windows 2000.
What happens is a window opens to My Computer, showing the icons for
C_Drive, Control Panel, etc.
I can't seem to get it to find the aaa.html file itself. If I put aaa.html
file inside the doc plugin folder and use <a href="aaa.html"
target="_blank">, then it will open a new browser and load the help system
and load the aaa.html file.
But if I put aaa.html in another directory on the Windows filesystem, I
can't seem to create an href construction that will load the aaa.html file
in its own window. I get a "My Computer" window.
Any hints on what tagging to try?
--Lee Anne
"Konrad Kolosowski" <konradk@ca.ibm.com> wrote in message
news:ceoolj$pg8$1@eclipse.org...
> site</a>
> will do.
> > Hi,
I
file
> it
> > coded as:
> > window?
> > file1.html
> > file2.html
> > file3.html
> > c://samplefiles/
> > aaa.html
> > bbb.html
the
> > Thanks!
> > --Lee Anne
Re: Can I link from a topic in the help system to an HTML file on the machine and load it in another [message #265455 is a reply to message #265305] Wed, 04 August 2004 17:19 Go to previous message
Lee Anne,
I have tried on Windows 2000 and it works too. For example:
<a href="file:///E:/eclipse3.0/eclipse/notice.html" target="_blank">See
this Web site</a>
Make sure the file exists, and you specify URL for the file protocol
correctly: start with file:///, use forward slashes, and URL encode any
special characters in the path.
Konrad
Lee Anne Kowalski wrote:
> Hi Konrad,
> --Lee Anne
> > site</a>
> > will do.
> > > Hi,
> I
> file
> > it
> > > coded as:
> > > window?
> > > file1.html
> > > file2.html
> > > file3.html
> > > c://samplefiles/
> > > aaa.html
> > > bbb.html
> the
> > > Thanks!
> > > --Lee Anne
Previous Topic:Missing action for 'External Tools Launch Configuration'
Next Topic:Adding/Removing pages dynamically in a MultiPageEditor
Current Time: Tue Nov 18 15:21:20 EST 2025
Powered by FUDForum. Page generated in 0.04028 seconds
