Home » Eclipse Projects » Eclipse Platform » Error when copying text with V3
Error when copying text with V3 [message #265211] Tue, 03 August 2004 06:48 Go to next message
Originally posted by: fred_so.hotmail.com
I am experiencing the following error message when copying text from the
editor:
The command for the key you pressed failed
Reason:
J2SE 1.5 parser not implemented yet
Any way to solve this? I cannot copy text at all at the moment.
Fred
Re: Error when copying text with V3 [message #265253 is a reply to message #265211] Tue, 03 August 2004 12:34 Go to previous messageGo to next message
Originally posted by: daniel.megert.gmx.net
FAS wrote:
> Hi
> the editor:
> Reason:
Looks like you use R3.0 + cheetah (1.5 support). Try todays integration
build: cheetah is now part of the 3.1 development stream and no longer a
separate thing.
Dani
> Thanks
> Fred
Re: Error when copying text with V3 [message #265313 is a reply to message #265253] Tue, 03 August 2004 21:04 Go to previous messageGo to next message
Thanks Daniel for the direction.
I don't use J2SE 1.5. Why do I get into this situation? Any way to get
rid of the 1.5 support to remove the error I am getting.
Fred
Daniel Megert wrote:
> FAS wrote:
>> Hi
>> the editor:
>> Reason:
> separate thing.
> Dani
>> Thanks
>> Fred
Re: Error when copying text with V3 [message #265345 is a reply to message #265313] Wed, 04 August 2004 06:34 Go to previous message
Download Eclipse SDK (not Platform SDK) R3.0 and install it into an
empty directory.
Dani
> Thanks
> Fred
>> FAS wrote:
>>> Hi
>>> the editor:
>>> Reason:
>> integration build: cheetah is now part of the 3.1 development stream
>> and no longer a separate thing.
>> Dani
>>> Thanks
>>> Fred
Previous Topic:Decoratior for non resources
Next Topic:Eclipse stopped booting?
Current Time: Thu Nov 06 20:53:14 EST 2025
Powered by FUDForum. Page generated in 0.03987 seconds
